rotating crank for TDC am I missing something? Really hard to turn
  • BaltimoreBimmer
    • Apr 2016
    • 307
    Do I need to have the car in neutral for this to work? If so, fuck the bently because it does not say that anywhere; I've read it several times over.
    Tried to move the crank (with sparks out) and it will move, but with a lot of pressure and then it will slightly rotate back. If car can be in gear... what gives?
  • gart
    • Jul 2012
    • 295
    Well it's going to try to turn the wheels if in gear and ebrake is not engaged. In other words yes put it in neutral.
    89 325 cabrio in progress m52tub28 swap
    99 540it
    86 Volvo 240 wagon
    99 Cherokee
    13 Passat
    • BaltimoreBimmer
      • Apr 2016
      • 307
      Thanks Gart....
      Sweet. Thanks for nothing Bently once again. (also, no DIY I saw mentioned it).
      Is it possible for me to have messed stuff up by attempting to rotate?
      • digger
        • Nov 2005
        • 6194
        Should be fine People push the car in gear to rotate the engine when doing valve adjustments. It helps to Also remove spark plugs
        • dnguyen1963
          • Nov 2011
          • 2651
          The Bentley does assume a certain amount of knowledge. If you read the DIY about locating the TDC, many will tell you to jack up the rear then put the trans in 5th gear to help rotate the crankshaft. If you have an auto then the trans has to be in neutral. It all makes sense after you cool your temper and think about the situation.
          • BaltimoreBimmer
            • Apr 2016
            • 307
            Originally posted by dnguyen1963
            The Bentley does assume a certain amount of knowledge. It all makes sense after you cool your temper and think about the situation.
            It's all good. I'm enjoying working on this car. Just slightly annoying the bently for both the e46 and e30 have so much incorrect information. Also, the Bently does technically say it is designed for people with no prior auto skills in the intro pages. And finally, the car being in gear was the very first thing I thought it was, which was why I double checked by posting it here.
            Cheers and thank you for helping me out!
            • george graves
              • 20003
              To avoid any future confusion, the engine should not be running while changing the timing belt - the Bently skips over that part.
              Originally posted by Matt-B
              • AndrewBird
                The Mad Scientist
                • 11898
                to avoid any future confusion, the engine should not be running while changing the timing belt - the bently skips over that part.
                zing!
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Oh..I've done that...and will do a write up on it...as soon as the casts come off ;D
                  Alice the Time Capsule
                  • george graves
                    • 20003
                    Is this how you do it?
                    Skip to 0:20
                    • BaltimoreBimmer
                      • Apr 2016
                      • 307
                      hahahahahahahah. I came prepared:
                      nothing can penetrate my flame suit. Keep it coming guys
                      • BaltimoreBimmer
                        • Apr 2016
                        • 307
                        Alright, one more question while I have my flame suit on....
                        Edit: holy fack that is one big ass picture.
                        In this picture, what is the sprocket I have my finger next to? This one seems to move very easily so I am assuming it doesn't matter if you rotate that one. Bently says only to not rotate the crank or camshaft which I have identified as the uppermost and lower most sprockets (tensioner in the middle left)
                        • digger
                          • Nov 2005
                          • 6194
                          that is the intermediate shaft that drives the oil pump located in the bottom of the block/oil pan. there is no required phasing relationship to either the crank or cam sprockets so you dont need to align it in any special way
                          • BaltimoreBimmer
                            • Apr 2016
                            • 307
                            Nice, thanks digger. My heart skipped a beat there but then I figured there's no way something that loose could be required to stay aligned. Phew!
                            Also apparently imgur doesn't like my iPhone upload...
