Camshaft seal not sitting evenly. Will it leak?
  • BaltimoreBimmer
    • Apr 2016
    • 307
    Finding it hard to press in the camshaft seal evenly. I have a 36mm socket that fits perfectly around the lip of the seal to press it in. I recall when taking it off that it was perfectly flush with the outer lip. My new one I seem to have pressed in too far. Do I need to remove it and start over? I do have a spare seal. Also since when does a regular imgur upload get this big....
  • CrazyPrime
    • Jun 2014
    • 286
    Left is higher then right side? If it was me I would just redo it even if you have to buy a new seal. It's not worth the risk if it does leak.
    Sent from my E6653 using Tapatalk
    • digger
      • Nov 2005
      • 6216
      if its evenly pushed in a mm or two further than before its ok provided its not sitting on a previous worn groove. usually its a good idea to have it sitting slighty further in or out from previous so it hits a fresh part of the shaft as long its not binding or out of square/twisted
      • BaltimoreBimmer
        • Apr 2016
        • 307
        I thought I had read that somewhere. It's as even as I'll get it for now. I will be taking it back apart over the winter to truely clean the engine bay anyway so if it does seep I'll find out
