1990 M20 Swap to 1985 325e
  • Lirker
    • Apr 2015
    • 60
    Hello all.
    1990 M20 automatic, swapping whole head and block into 1985 325e.
    I want to use the manual transmission on the 85 325e.
    My questions are;
    The wiring harness on the 325e has 2 sensors leading to the early eta transmission for crank position sensors. The 325i harness doesn't have these. What do I do about that?
    Also, is there anything else I need to look out for the swap as far as transmission goes like fitment or compatibility?
    Btw I already have the adapter from round to square plug.
    Lirker
    '90 325i
    85' 325IE
  • reelizmpro
    • 9552
    You should run everything from the 325i including Motronic 1.1/1.3 which doesn't need those sensors on the transmission. Just removed them. You'll need to swap the flywheel also.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Lirker
      • Apr 2015
      • 60
      So the dual mass flywheel that's on the 85 transmission won't work?
      Lirker
      '90 325i
      85' 325IE
      • reelizmpro
        • 9552
        It will, I meant swap the automatic flywheel to the manual trans one.
        88 M3 - LACHSSILBER
        • Lirker
          • Apr 2015
          • 60
          thanks i sent you a PM
          Lirker
          '90 325i
          85' 325IE
          • TobyB
            • 5280
            automatic flywheel
            aka torque converter?
            Yes, you can keep the 85 style clutch and flywheel.
            You may have trouble with wiring- is your 85 a square body- to- engine harness connector?
            If it's round, check pin 20- early cars used that for ground, late cars used it for airbag
            (or something) power, and when the 2 meet, smoke gets out. did that...
            If it's square, look for the writeup on how to splice the 2 together...
            t
            • Lirker
              • Apr 2015
              • 60
              t
              Thanks for the reply. I actually have an adapter ready to go thats spliced. it's square on the 85. so I have that settled already. Do I still need to worry about pin 20?
              What about the throwout bearing, do i need a different version? or is everything okay
              Lirker
              '90 325i
              85' 325IE
              • TobyB
                • 5280
                If you use all 85 parts, they will work fine. The deeper bellhousing is offset by the thicker flywheel.
                You do need a pilot bearing in the crankshaft, but you knew that.
                If the adapter is made for a late engine harness you should be fine.
                If I recall, the problem is when a green body harness wire mates to a red engine harness wire...
                t
                • Lirker
                  • Apr 2015
                  • 60
                  t
                  Such great help. Thanks a lot fam.
                  Lirker
                  '90 325i
                  85' 325IE
