Repling head gasket, what else should I replace?
  • e30rotorhead
    • Sep 2016
    • 6
    I'll be doing s head gasket replacement to fix an oil leak. What else should I replace while im in there? I'm counting on replacing the exhaust manifold gasket. The water pump and timing belt were replaced recently. Anything else I should consider while im in there?
  • e30rotorhead
    • Sep 2016
    • 6
    Thanks for the help - in advance.
    • digger
      • Nov 2005
      • 6180
      replace the belt since it gets detensioned.
      think of replacing things for coolant, manifold, t-stat etc
      • PKile
        • Apr 2016
        • 184
        Intake manifold gaskets, head bolts of course (they are one-time use only), valve cover gasket and rocker shaft plugs, oil drainback tube o-rings. Also remember to check the valve adjustment only after the head has been re-installed and torqued. Use an OEM BMW head gasket for best reliability.
        • e30rotorhead
          • Sep 2016
          • 6
          Thanks for the recommendation. Anyone have anything else? Where is the best place to buy the parts? I'd probably go to pelican by default but I'm not sure I'd there is a place that is typically cheaper.
          • dnguyen1963
            • Nov 2011
            • 2651
            http://www.rmeuropean.com/Make/BMW.aspx#Category
            BluntTech is your source for quality auto parts and accessories. Shop online for home delivery or pick up.
            And a few other places...
              Just a hint...
              When re-assembling torque the head bolts to the initial 22ft-lb. Then re-install everything else, making sure the cam timing is correct. The last step is final tightening of the head bolts. The reason for this procedure is that you won't have to replace the head bolts again if the head has to come back off.
              • PKile
                • Apr 2016
                • 184
                Originally posted by jlevie
                Just a hint...
                Great tip jlevie! Luckily my rebuild went fine, but I will do that next time.
