Rebuilding m20...had some questions
  • Supratreo
    • Aug 2016
    • 135
    Hi, just a couple quick questions for you guys.
    I'm revealing a complete m20 and there are a couple things I wasn't sure about,
    1. When installing the timing belt, there's a small t belt driven pulley next to the crank, does this also need to be timed? Like an idiot I didn't mark it at all and if it's a balance shaft then they are usually timed.
    2. Is there supposed to be a gasket between the oil pump and block? I don't think this motor had one but it's a weird place to have a metal on metal seal.
    3. Do they sell a gasket for the coolant manifold that is mounted to the TB? I can probably make one but it's gonna be a PITA.
    Thanks for your help
  • digger
    • Nov 2005
    • 6199
    1) the other gear drives the pump so not timed (might be different on 323i though dont know)
    2) no gasket
    http://www.realoem.com/bmw/enUS/show...diagId=11_0446
    3) http://www.realoem.com/bmw/enUS/show...diagId=13_0334
    https://www.ecstuning.com/b-original...541285471~oes/
    • Supratreo
      • Aug 2016
      • 135
      U the man. Thank you very much
