Low idle when cold outside temp (-3°C or 26°F)
  • D.Martijn
    • Sep 2016
    • 1023
    Hey everyone,
    I noticed today as it's getting colder (-3°C) my 325ix had a pretty low idle just above 500rpm, when I turned on my lights as it was already dark outside I could notice them reducing brightness and then intensifying over and over again.. It didn't stall though.. As I arrived back home, the car idled like usual.
    Anyone that has an idea what the problem could be?
    1990 325iX Touring - November 2018 R3V Car Of The Month
    1980 Volkswagen Golf mk1 1.1
    1974 BMW 2002 Touring
    Instagram
  • dnguyen1963
    • Nov 2011
    • 2648
    On cold days, I would wait until the temp needle pops into the normal reading range before I turn on any electronics. On a really cold day (below -9C), the tach needle would move up and down from about 500 to 900 rpm until the engine is warmed up. It has been doing this forever during the winter months. Once the engine is warm, everything behaves as normal.
    • D.Martijn
      • Sep 2016
      • 1023
      I usually wait a minute before pulling out, once I'm on the road I make sure not to push the engine till it's warmed up.
      Could it be the blue temperature sensor acting up? If I'm right this sensor tells the ECU what temp the engine is so the ECU can adjust the fuel delivery.
      Instagram
      • dnguyen1963
        • Nov 2011
        • 2648
        I think it is the oil we used in our car. 15W40 is quite thick when the temperature drops that far. It takes a few minutes to distribute the oil evenly.
        • digger
          • Nov 2005
          • 6057
          ICV working properly? it should maintain slighty faster idle when cold
          • dnguyen1963
            • Nov 2011
            • 2648
            I have not checked. The ICV works fine when the temp is above 15F. I generally park the car on days when the temp drops too far.
            • squidmaster
              • Aug 2011
              • 2666
              Materials slightly expand or contract in temperature differences, wouldn't hurt to clean out the icv. Using a lower weight oil helps sometimes, too.
              • D.Martijn
                • Sep 2016
                • 1023
                Been using 10W40 oil which is a tad thinner than 15W40 when cold
                Haven't checked the ICV since I get home quite late, I'll check it this weekend. I'll report back :)
                Instagram
                • squidmaster
                  • Aug 2011
                  • 2666
                  Sorry, didn't notice you using 10w40. While that shouldn't be too bad for cold weather, I noticed a stark difference in startup and idle while very cold using anything over 10w30, with 20w50 making it worrying difficult to start on some below 0 mornings.
                  • dnguyen1963
                    • Nov 2011
                    • 2648
                    The reason I don't use anything thinner than 15W40 is that the car does not take very long to get up to temp (yes, 10W30 can give you an easier starting) and, when the engine is at operating temp, lower viscosity oil does not offer adequate protection.
                    • D.Martijn
                      • Sep 2016
                      • 1023
                      Today I cleaned my ICV. When loosening the hose clamps I noticed that the little elbow that's fitted on the throttle body was loose.
                      I decided to remove it and seal it up again with sealant.
                      I'll report if this fixes my idling
                      I also noted that the little tube has some small cracks in it, so I've ordered a new one from BMW.
                      Instagram
                      • dnguyen1963
                        • Nov 2011
                        • 2648
                        Very common problem.
                        • D.Martijn
                          • Sep 2016
                          • 1023
                          Problem seems to be fixed.
                          By sealing the little elbow and cleaning out the ICV.
                          Instagram
