Hello. Ive been a long time reader. I wanna start off by saying this post is pretty lengthy so beware. I recently purchased a non-running 86 325e. I purchased it with the intent of getting it on the track. It is a very solid car so I decided to invest the time and money into getting it ready. The entire car was in stock form when I purchased it. There is zero rust, but ALOT of maintenance was deferred, and parts had gone well past their life expectancy. The car could not be run due to a severe oil leak from the rear main seal.
I put a lot of hours into this car over the last month getting it to where it is now. However, I am still struggling to get it running properly. After pulling the motor, cleaning, re-gasketing, and re-installing, I ran into many problems. First, it wouldn't start at all. I traced this back to a faulty cps. I replaced both for good measure and it fired right up. Now running, it had a huge surging idle. I traced this back to the ICM. I replaced it with a used unit. Surging went away, and the ICV was operating correctly. During these tests, I also found a faulty TPS so that was also replaced.
Now I am at the point where the car starts and idles, but doesn't do much beyond that. If I open the throttle and hold it at the same spot, the rpm's will wander down then up rhythmically. Also, if I try to open the throttle in any type of rapid succession, it will respond to the first blip, then maybe the 3rd or 4th. In between it just doesn't respond at all. I checked fuel pressure at the rail, and all seems good. I checked compression and all seems good. I checked for spark and injector pulse, and all is good. I ran all of the Bentley tests at the DME and everything checks out. I am getting the proper resistance from the coolant temp sensor, and I also checked the cold start system for proper function, and all is well. Thermo time switch is working properly. I swapped in a good used DME, but no change. I swapped in a good used AFM, but no change. I tested main relay & fuel relay. All is good. I checked fuel pumps (both new), filter(new), and FPR(new). All is good.
Im at a complete loss at this point. The only test that has not been done on the car at this point is a smoke test for vacuum leaks, but I can't see this being the issue based on symptoms and being that I replaced all vacuum lines. I dropped the car off at a local shop last week for them to look at it just in case I'm missing something obvious and simple. No luck on their end yet and they've looked at it for 2 days. Im very frustrated because I was expecting to get this motor running with half this effort and cost. This engine honestly isn't worth this amount of time or money to fix. Im at the point where I need to stop the bleeding, cut my losses, and just pull the motor again. It looks like this is the route Im going to take if the shop doesn't return with any good news.
My next course of action is to swap in an M20B25 motor. I have been doing a lot of research into this swap, and it appears to be very simple and straightforward. I am trying to plan everything out now so I do not have to stop working once the swap begins. I don't want to realize halfway into the swap that I have a wrong part. So Im here looking for some information to make sure this doesn't happen. I also want to see exactly which parts I can salvage from my existing 'e' motor/transmission. I have a good idea for most of what needs to be done. I plan on putting in the 'i' motor, AFM, DME, and wiring harness. I understand that anything other than the 87 harness will need C101 pin #20 cut in order to prevent shorting the ABS circuit. I also need to rework C104. So here goes.
1) Can I transfer my 'e' single mass flywheel and new clutch kit over to the 'i' transmission? Im not sure if Ill get the 'e' motor with or without the transmission, so Id like to be proactive and just plan ahead for both scenarios using either transmission.
2) Can I transfer the new water pump? Im assuming it'll work so long as I keep the 'e' cooling system in place. I believe the 'e' water pump has a provision for a return hose.
3) Any issues with transferring the timing belt, tensioner, ignition coil, cap, rotor. Im pretty this is all fine, but I want to be 100% sure.
Some, but not all things that have been finished so far:
- Front and Rear Subframe powder coated with reinforcements welded in for differential, sway bars, and motor mounts.
- New polyurethane bushings- subframe, trailing arms, differential, and front control arms.
- New heavier duty motor and transmission mounts.
- Rebuilt shifter assembly
- New clutch kit. Resurfaced flywheel.
- New rear axles
- New front wheel bearing
- Bilstein Sport Suspension w/ H&R Race Springs.
- Rebuilt calipers, ss brake lines, rotors, pads
- New driveshaft flex disk & center support bearing.
- New complete SS exhaust (headers to muffler are dual pipe)
- Replaced ALL cooling hoses
- Replaced ALL vacuum hoses
- Cleaned/Tested fuel injectors
- Replaced TPS, ICV, ICM, AFM, DME, spark plugs, coil, wires, cap, rotor, timing belt, water pump, and accessory belts.
- Re-gasketed the motor (rear main seal, oil pan, valve cover, head gasket, rocker end seals, intake/exhaust manifolds, throttle body, etc)
If you made it to this point, then I appreciate your patience and time in reading this. Thank You.
PICS:
Day of arrival
![](https://www.flickr.com/photos/150793688@N08/shares/c5Bp5L)
New Wheels & Tires
![](https://farm1.staticflickr.com/472/32042351495_0240a6a355_c.jpg)
Front Suspension & Brakes:
![](https://farm1.staticflickr.com/477/32042352735_0fd9b45199_z.jpg)
![](https://farm1.staticflickr.com/283/31894279272_1c5b7aaf2a_z.jpg)
![](https://farm1.staticflickr.com/454/31924713771_e252df4b86_c.jpg)
![](https://farm1.staticflickr.com/716/31924714391_2e853ae9b9_z.jpg)
Motor, Rear end, & drivetrain work:
![](https://farm1.staticflickr.com/359/31894297132_73ed3c5bf5_z.jpg)
![](https://farm1.staticflickr.com/397/31924717321_23600f6d21_z.jpg)
![](https://farm1.staticflickr.com/496/31894298142_ac8194275d_z.jpg)
![](https://farm1.staticflickr.com/433/31894297532_cbface0e24_c.jpg)
![](https://farm6.staticflickr.com/5602/31201532904_064dd130e5_z.jpg)
![](https://farm1.staticflickr.com/263/31201536014_6aa9585be8_c.jpg)
![](https://farm1.staticflickr.com/272/31201539404_5e094d1d6e_c.jpg)
![](https://farm1.staticflickr.com/508/31201540694_7567ea59ed_c.jpg)
![](https://farm1.staticflickr.com/716/31201542584_103c535a0a_c.jpg)
![](https://farm1.staticflickr.com/647/31201546944_3d1423c327_z.jpg)
![](https://farm1.staticflickr.com/381/31201548314_0302ba9482_c.jpg)
![](https://farm1.staticflickr.com/326/31201549304_d46ed20343_z.jpg)
![](https://farm1.staticflickr.com/593/31201550754_8d88b073b7_z.jpg)
![](https://farm1.staticflickr.com/468/31201552344_701da9844d_c.jpg)
![](https://farm1.staticflickr.com/598/31201556684_3feeeac6ea_c.jpg)
![](https://farm1.staticflickr.com/613/31894313172_4446dd43b7_z.jpg)
![](https://farm1.staticflickr.com/475/31894316152_081cb462db_z.jpg)
![](https://farm1.staticflickr.com/447/31667515400_d8b8721de8_z.jpg)
![](https://farm1.staticflickr.com/406/31894310202_2a9bae5ff6_z.jpg)
![](https://farm1.staticflickr.com/596/31201534584_3c508a6f84_c.jpg)
![](https://farm1.staticflickr.com/722/31201537844_3a33ee8a1c_c.jpg)
![](https://farm1.staticflickr.com/447/31894311902_5b9733eecc_c.jpg)
- New rear axles
PICS:
Day of arrival
New Wheels & Tires
![](https://farm1.staticflickr.com/370/31232490183_04a159255e_z.jpg)
![](https://farm1.staticflickr.com/691/31894314942_e81e4206c2_c.jpg)
