Valve Cover Hardware
  • tcblenny
    • Dec 2015
    • 10
    Hey y'all, I snapped one of the valve cover studs and I don't know where/what to order.
    So far, I only know that they are m6x1.0 but I cant seem to find the hardware on Pelican or Bavauto.
    Can anyone help me out? :/
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5597
    get an m6 bolt, cut the head off, drink beer, rejoice.
    I take pee pee touches for tips, given the fact that you're local, we can make this happen
    • tcblenny
      • Dec 2015
      • 10
      Awesome I'll just go that route then.
      Haha, there's gonna be two heads getting cut off if you want touchin :devil:
      Thank you so much!!
      • cscracker
        • Jan 2017
        • 131
        07129908103 if you want the actual part, as seen here for my car:
        http://www.realoem.com/bmw/enUS/show...diagId=11_1910
        But yeah, pretty much any M6 of appropriate length will do the job, it's not exactly a precision application.
        • jeffnhiscars
          • Jun 2011
          • 6011
          The caution though is that the stock studs are stainless which is quite hard. If you cut something similar it has the potential to do thread damage on the aluminum head.
          Not critical but for the $1 so that they cost seems like stock replacements are a best practice
          Alice the Time Capsule
          • digger
            • Nov 2005
            • 6180
            i dont think they are stainless, they are zinc plated/coated
            • jeffnhiscars
              • Jun 2011
              • 6011
              I think I pulled some SS studs but will check. Either way they are hard enough to damage aluminum and cheap enough to not be worth fabbing something.
              • digger
                • Nov 2005
                • 6180
                file the end after cutting and thread into a nut to make sure there are no burrs and youre GTG, works fine if you cant wait for real parts. you should be able to buy studs at most hardware stores anway
