Help: Throttle Plate Screws
  • qckslvr
    • May 2014
    • 15
    Does anyone know what size screws hold the throttle plate to the throttle shaft, and where to procure new ones?
    Yes, I ground off the back and removed the OEM screws for the purpose of cleaning a very gummed up throttle body...I assumed in the heat of the moment that I would be able to find replacements easily...but hours of searching has revealed nothing.
    '87 325is
  • jeffnhiscars
    • Jun 2011
    • 6011
    Did you check realoem to see if they are available by themselves ?
    Alice the Time Capsule
    • qckslvr
      • May 2014
      • 15
      RealOEM doesn't show the throttle plate, screws or shaft in the diagram.
      https://www.realoem.com/bmw/enUS/sho...diagId=13_0335
      '87 325is
      • digger
        • Nov 2005
        • 6207
        They look like m4 screws. I'll have check later I think I got a spare lying around
        • qckslvr
          • May 2014
          • 15
          Ok, looks like they are M4x.70, I picked up a couple stainless screws at the local hardware store. I'm going to use red loctite, and kill the threads on the backside to prevent them from becoming FOD.
          Thanks everyone.
          '87 325is
