M20 main caps
  • zaq123
    • Jul 2016
    • 1560
    M20 main caps
    On M20, any good tricks to install/uninstall these quickly and without damaging things?
    I'm planning to plastigauge the crank and will be taking these on/off a lot. Caps are pretty tight on M20 and I want to be able accurately record plastigauge measurements without distorting the line while removing installing caps.
    Any tricks of the trade for these engines? please share.
  • TobyB
    • 5287
    put a tight- fitting length of dowel- drill rod, or similar- into each bolt hole, compress them towards each other,
    and use that as a handle to wiggle them out of there.
    t
