M52 crank in M20, main bearings business
  • zaq123
    • Jul 2016
    • 1560
    TIS for M52:
    engine block side:
    "When the bearing shells or the crankshaft are replaced, the
    classification for bearing shell arrangement in the engine block is
    eliminated. Only install yellow bearing shells in the engine block"
    bearing cup side:
    "The bearing shell classification for the bearing cover is marked on
    the crankshaft in yellow, green or white paint.
    Place main bearing shells with same color code as that of
    crankshaft in main bearing caps
    Would this apply for M52 crank in M20 block? My M52 crank has two journals market green with the rest being yellow.
  • zaq123
    • Jul 2016
    • 1560
    anyone used different bearings on the same journal? Looks like that's what TIS is prescribing.
    • TobyB
      • 5287
      Sure- if the journal measures .0005" small, it's pretty standard to use one nominal and 1 .001
      under. Happens when you polish a standard crank, sometimes...
      t
      • zaq123
        • Jul 2016
        • 1560
        Just want to make sure I get correct parts:
        My Mains:
        1. 2.3616
        2. 2.3615
        3. 2.3615
        4. 2.3614
        5. 2.3616
        6. 2.3614
        7. 2.3613
        I need to order all yellow bearings for the block side.
        Cap side will be as follows:
        1. yellow
        2.green.
        3.green
        4.green
        5.yellow
        6.green
        7.green
        Am I going in the right direction with this?
        • zaq123
          • Jul 2016
          • 1560
          Am I looking into this too much....??
          Found some specs for Kolbenschmidt bearing set 87369600, STD size, .
          Based on these specs and sizes of my M52 crank main journals:
          2.3616'' (59.985mm) journal - radial clearance of 0.0007" (0.019mm)
          2.3613" (59.977mm) journal - clearance of 0.0011" (0.027mm)
          Looks like KS bearing kit will work ok?
          KS recommended radial clearance for mains based on KS specs (why min is smaller than Bentley's min of 0.020mm???):
          min: 0.014mm and max: 0.033mm (with 65mm bore)
          min: 0.033mm and max 0.052mm (with 65.019mm bore)
          KS specs:
          material St/A
          Bearing width 20.00 mm
          wall thickness 2.498 mm
          Min. shaft diameter 59.971 mm
          Max. shaft diameter 59.990 mm
          min. Housing bore 65.000 mm
          max. Housing bore 65.019 mm
          Distance crank web from 25.020 mm
          Distance crank web to 25.053 mm
          Axial play from 0.080 mm
          Axial play to 0.163 mm
          • zaq123
            • Jul 2016
            • 1560
            what do you guys think? Should I go with KS set and not worry about OEM green? Any thoughts why KS specs smaller oil clearance compared to OEM?
