M20 idle woes
  • ThatM20Guy
    • Aug 2014
    • 600
    M20 idle woes
    Didn't really want to start a new thread over this but couldn't really find another scenario quite like mine. The car seems to idle fine when it is up to operating temperature, but on a cold start it seems to run rich on the low end and then die.
    Things I've checked so far
    - Refurbished ICV installed
    - TPS seems to be working correctly
    - 95% of vacuum leaks solved
    - Cleaned AFM
    Only other thing I could think it would be is a dead coolant temp sensor. The car has new plugs with only about 40 miles on em (if that) and injectors seem fine.
    The only other intake leaks I know I have are on the metal elbows that attach the vacuum lines from the booster to the throttle body. They have just worn out their press fit and no longer stay in tight. Is it safe to JB weld these back into place or is there a better option?
    89' 325ix Diamantschwarz/Black rattle can...
    Insta: r_moose_w
    Originally posted by flyboyx
    I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
  • e30davie
    • Apr 2016
    • 1788
    yah you wanna fix all vacuum leaks, JB weld seems to be the way to go on those fittings from reading others experience.
    AFM engines just can't deal with vacuum leaks. your engine is more susceptible to vacuum leaks when its cold, once its hot it can put up with a slightly leaner mixture at ldle.
    • ThatM20Guy
      • Aug 2014
      • 600
      Thanks for the info. I'll JB weld those fittings this weekend and see if that doesn't fix it.
      Insta: r_moose_w
      • zaq123
        • Jul 2016
        • 1574
        I think this is your issue. Also check connector to it, could be corroded or just bad connection.
        • zaq123
          • Jul 2016
          • 1574
          • ThatM20Guy
            • Aug 2014
            • 600
            Thanks for the link. Going to try the JB weld first and see if that helps at all and then go ahead and replace the coolant sensor.
            Insta: r_moose_w
            • Shock(/\)ave
              • 350
              Once you get the vacuum sorted out, I would definitely try the coolant temperature sensor next. I keep a known good one on hand along with a clean idle control valve for M20 idle troubleshooting purposes.
              I'd then check your fuses, battery terminal connections, C101 connector and grounds. The majority of idle issues I've encountered that weren't simple fixes were related to issues with the electrical system.
