M20B32 86mm headgasket
  • Schlander
    • Dec 2016
    • 26
    Got the other rods today, M54B30, will try to testfit the tomorow.
    They are here compared with the following.
    M54B30 135mm - M20B25 135mm - S50B32 Euro 138,9mm
    And then M54B30 on top of a M20B25 rod.
    • suruba
      • Sep 2013
      • 159
      it looks like the m54b30 rod is the one to use over the m20 rod?
      Dave
      • digger
        • Nov 2005
        • 6198
        Yeah 24v rods clear the bottom of the bore much better as a result.
        I got an email from Athena and they can do custom 86mm gaskets minimum 15 order, not really what I was looking for and they didnt answer my questions.
        • Schlander
          • Dec 2016
          • 26
          I've found the gasket from Cometic :)
          86mm 0.098"/2,5mm
          Item number H1244SP1098S
          They don't have shown on their site.
          Bought mine here.
          • dude8383
            • Jan 2005
            • 10387
            I can get the JE/Athena one, it's a cut ring thats 85.5mm:
            Shoot over your address I can get you an estimated cost. Might be able to beat those guys :up:
            *EDIT* whoops I see that you need the .098mm variant.
            Having said that, I can get the cometic variant as well :up:
            C4394-098
            BMW M20 2.5L/2.7L 85mm .098 inch MLS Head Gasket 325i/525i
            • digger
              • Nov 2005
              • 6198
              There a dozen or so thicknesses cometic will make in a custom bore for m20. It's not a difficult problem to solve
              The Athena won't work with the 86mm. I did ask if you could use one of the steel rings / inserts from a S52 and add to the m20 gasket but got no response that clarified and I gave up
              • ForcedFirebird
                • Feb 2007
                • 8300
                FWIW I have been using Cometic gaskets for years on various builds without issue - even when the block was not decked for the 50ra. I drill the rivets out and put a light layer of copper spray on each side of the layers.
                I find it odd that people are concerned about MLS gaskets when the Elring and VR replacements leak about 90% of the time at the front oil return passage.
                john@m20guru.com
                Links:
                • digger
                  • Nov 2005
                  • 6198
                  its just cost, but if you are using 86mm forged pistons with a full rebuild then in the grand scheme its not the end of the world. i complied a list of thicknesses sometime ago
                  1.02
                  1.14
                  1.30
                  1.52
                  1.73
                  1.78
                  1.91
                  2.03
                  2.18
                  2.26
                  2.34
                  2.49
                  3.05
