Messed up stroker, WWYD?
  • Dagamus(NM)
    • 620
    Originally posted by digger
    then there probably isn't much point running getting new pistons
    Other than getting to run lighter stronger rods I suppose not. Rod/stroke ratio would be higher but other than that everything else would be conserved.
    Heavy rotating mass. Will be interesting to see the power curve on the dyno. Might be benefit to keeping RPM a little lower than if I had used the s50 rods.
    Gun control means using both hands
    Sex, Drugs, Rock 'n roll. Pick two.
    • digger
      • Nov 2005
      • 6176
      unless you are planning a ton of boost or rpm then those things are not that big a deal IMO
      • Dagamus(NM)
        • 620
        Nope, just a healthy street tuned setup.
