Valve Cover Bolts
  • Idrisu
    • Jul 2015
    • 173
    Valve Cover Bolts
    So as I was taking off my valve cover two of the bolts came out with studs. Any ideas on what I should do? They can screw back in to the holes.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5611
    • Idrisu
      • Jul 2015
      • 173
      There wont be any leaks?
      • Dagamus(NM)
        • 621
        As long as your gasket seals and your head/vc aren't warped you should be good.
        If it makes you feel better you can put a tiny bit of thread sealer (loctite blue) and thread the stud in, then torque to spec.
        Gun control means using both hands
        Sex, Drugs, Rock 'n roll. Pick two.
        • Das Delfin
          • Sep 2014
          • 2293
          it won't leak, just put them in all the way using the two-nut method
          • Idrisu
            • Jul 2015
            • 173
            Looks like both of them aren't tightening down, they just keep turning and turning. I believe its now causing a leak because my RPMs keep jumping and it feels like that car is going to stall out. It never did it before.
            • e30davie
              • Apr 2016
              • 1788
              Bit of thread locker mate, and she'll be right.
              Once you get the bolt back in with a decent (or new) tappet cover gasket the nuts do not need to be that tight. They are only m6 thread or whatever. don't over do it.
              • Seawolf
                • Feb 2015
                • 270
                And if the thread is iffy feed some copper wire into the hole and screw the stud in, the wire will provide enough of a key to hold the stud.
