885 Head
  • RichiesE30
    • Jul 2016
    • 37
    885 Head
    So I can get an 885 head with all internals for $100 bucks. This a pretty good deal? Thinking about swapping the head and accessories onto my stock eta bottom end. Also, how much should i expect to pay a shop to swap the head? Just so I know the options. May just end up doing it myself.
    Thanks.
    Also, I've read all the posts on whats needed and have been searching for awhile. Might get the head blocked so it matches up better with the pistons. Also, would probably be turbo'ing later so I will probably end up running a different management system.
  • barbierij
    • Sep 2012
    • 1294
    It should be whatever the book time is to replace a head gasket.
    FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
    Saab/GM tech2 programming
    My for sale thread
    1990 325iX for sale or part out
    Did you buy something from me? Please leave feedback!
    Originally posted by K20RI_211
    And I have to ask if you make a hobby out of thread-bombing with retarded questions?
    • jeffnhiscars
      • Jun 2011
      • 6010
      Don't forget the machine shop cost to refurb the head, possibly new cam and the WYAIT items
      Alice the Time Capsule
      • ahlem
        • 369
        $100 is a very good deal but expect to spend $150 or more at the machine shop with their work. Have them check valve guides, valve seats, valves and for flatness and cracks.
        Look for rockers with concaved surfaces and replace those. Look for scoring on the cam and cam journals and replace the valve guide seals and other seals.
        You have to replace the head bolts (~$45) and all the gaskets too. Gasket sets for the top end are about $120 and then you will be replacing the timing belt, tensioner and probably water pump.....
