Piston Ring Gap to Block Orientation
  • bw86newman
    • Feb 2015
    • 17
    My machinist told me to check with the engine specs on what direction/orientation the ring gaps should be in relation to the block itself. Does anyone know what this should be. I know the manual says to keep the ring gaps offset from each other by 120 degrees, but I couldn't find where its says which ring gap should be facing to the front/back/side of the block.
    Thanks
  • zaq123
    • Jul 2016
    • 1570
    standard orientation should work. Rings will move with the stroke though if cylinder hone is done properly, basically the orientation is just a reference point.
