camshaft bearing surfaces
  • zaq123
    • Jul 2016
    • 1560
    Installing new cam and want to make sure bearing surfaces are not going to mess it up. My old cam was in otrocious shape. Head was machined and cleaned very well. I installed new cam to measure valve lift etc and noticed that after a few rotations, new cam has marks on its journals (not scratches, just very slight marks). I inspected bearing surfaces and noticed that the aluminum has a few tiny metal specks embedded in them. Probably shavings from the old cam/rocker pads. I'm not sure if they will mess up my new cam and if those marks turn onto groves but I don't want to take any chances. Head cam bearing surfaces don't look too bad otherwise.
    Any good way to clean them up? Though about lightly spot sanding them but don't want sand paper particles getting embedded there as well.
  • yosh
    • Aug 2009
    • 350
    Did you use assembly lube when turning the cam? It should probably be lubed up well if turning a new cam in there.
    Sent from my VS985 4G using Tapatalk
    • digger
      • Nov 2005
      • 6199
      scotchbrite pad? honetool
      • yosh
        • Aug 2009
        • 350
        Don't they say scotchbrite leaves behind a residue or compound not good for the metal?
        • zaq123
          • Jul 2016
          • 1560
          I just used some w50 oil for mock up (test soft springs in there now), no assembly lube yet.
          I guess I can try some scotch bride there, maybe 600 or 800 grit paper? What RA finish is acceptable for the bearings? 600 should be about 8-12 (0.2-0.3Mm). Or should I do 800 for RA 3-10?
          yosh, my understanding scotchbrtite, sandpaper is no no if it's the final assembly (pre-assembly deck surface, bores with pistons installed etc). I think a brush and some soapy water should get all that Al. oxide out of there.
          • digger
            • Nov 2005
            • 6199
            still gotta clean it, scrub it, clean it, scrub... one way or another regardless. its not hard to pull apart the head and clean it especially when the cam isnt even in yet
