Crankshaft bolt question
  • Chrisbike
    • Mar 2015
    • 688
    Ok. SO. I removed this bolt so I could remove the pulley and reseal the front cover..
    I ordered the sir crankshaft holder and am wondering if I need a new bolt, Ive been told its a torque to yield which wouldn't surprise me since it needs to be torqued to 305ft/lbs according to a thread I found on SpecE30. I haven't found this in the Bentley yet.
    I also found this... Seems like this person didn't replace it and just torqued it to 150ft/lbs with medium strength loctite on the threads
    http://www.angelfire.com/blues2/bimm...crankbolt.html
    Can anyone confirm this?
    Build Thread
    https://www.r3vlimited.com/board/sho...d.php?t=419655
    Parts Thread
    https://www.r3vlimited.com/board/sho...d.php?t=408302
  • digger
    • Nov 2005
    • 6194
    should be fine to reuse assuming it wasnt installed wrong by a previous owner, as according to this
    the torque to use can be somewhat higher for a M18x1.5 black GR12.9
      That bolt is not a torque-to-yield type.
      • e30davie
        • Apr 2016
        • 1788
        That torque spec is in the bently somewhere i found it. It's a masssive torque, its so massive that i dont think it matters too much if you are a bit off. 305ft/lb to N/m - 410N/m - massive.
        I have a 500mm breaker bar, i weigh about 90kg, i stood on the end of the breaker bar, based on the following maths.....
        90kg = 882N, and 882 x 0.5m = 441Nm. Pretty close to the requirement.
        Not the most scientific method, but yeah i dont have a torque wrench that big....
        note: i did this with engine out of car, in the car might be a bit more tricky...
        I also put some paint pen on the bolt and the hub so that i can see if the bolt has moved. i periodically check it when under the car (which is far too often...) and its not moving:)
        Second note: I welded a bar to a spare harmonic ballancer to hold it still. works good, but yeah you need a spare harmonic balancer....
