Im having trouble finding a clutch that will hold up with my turbo ix and still be nice and streetable. Right not im using the uuc 240mm m5 clutch kit with there segmented kevlar disk. Would good for about 6 months but after a few launches its already slipping trough 3rd at low boost. Now my car does have a slight oil leak which could in theory could be getting oil vapors in the clutch and causing it to slip. Either way it needs replaced and im not in the mod to do it again. I want something that will support over 500ft lbs of torque and be nice to drive, so im thinking twin disk. I called up uuc and they said i can use the e36 twin disk setup as long as i use the correct starter. For some reason that just sounds to easy, why havnt i seen other people do it? Anyone know of this is true and it will actually work?
https://www.turnermotorsport.com/p-3...328-z3/?pdk=Ag
Says here it will fit 5 series with m20
Thanks stevan
Sent from my SAMSUNG-SM-G891A using Tapatalk
Thanks stevan
