Fuel Pressure Questions
  • Blobsters
    • Dec 2016
    • 7
    1990 325i Sedan (M20)
    Generally when cold starting my idle is rough and around 550 rpm
    When I blip the throttle the car rpm drops and the engine sputters before gaining rpm
    Overall lack of power
    old compression test results here: https://www.r3vlimited.com/board/sho...d.php?t=399036
    I have replaced the fuel filter and the lines before and after the filter with R9 hose (was leaking fuel, the lines were dry rot)
    I replaced the fuel line to the fuel pressure regulator and the vacuum line to the fuel pressure regulator
    I installed an inline T to a gauge on the fuel line below the fuel pressure regulator. Setup as seen in this pic:https://drive.google.com/file/d/0B34...ew?usp=sharing using this gauge: http://a.co/6PNywuD
    At idle (idling around 900) the gauge read ~38 psi stable
    When the throttle was blipped the gauge would shoot up to 50+ and with rpm gain the pressure would drop back to ~38 in seconds (hard to see while inside vehicle)
    When pinching the vacuum line to the fuel pressure regulator the pressure was a stable 45 psi, when released it returned to 38
    After the car was turned off, the pressure remained at 38 for 15+ minutes.
    The car was filled with 89 octane fuel and was approximately 75% full during the test
    Have I properly tested my fuel pressure and FPR? What do these results indicate if they have been taken correctly? If they were not taken correctly, or I have missed something please let me know.
  • jeffnhiscars
    • Jun 2011
    • 6011
    Best practice is to confirm 100% that you do not have any intake leaks. A smoke test is the best way to accomplish that.
    Alice the Time Capsule
      Fuel pressure at idle should be about 38psi. At higher engine speeds it should be about 43psi. Tie wrap the gauge to a windshield wiper and see what happens as you drive.
      • ahlem
        • 369
        My suspect would be clogging injectors or old cracking injector O rings. You didn't state mileage and injector condition.
        Any fuel in the vacuum line to the FPR?
        • Blobsters
          • Dec 2016
          • 7
          230k+ miles , no fuel in vacuum line to FPR, unknown condition of injectors. Will pull injectors and flow test/ clean / replace clips/seals.
          • parkerbink
            • Jun 2004
            • 10138
            Have you checked the fuel return?
            • sert57
              • May 2014
              • 170
              sub'd - I'm suspect of mine as well. If I find anything with mine ill report back here, similar situation except for lack of power.
              • sert57
                • May 2014
                • 170
                my caused ended up being the injectors, i have a stroker motor with a few bolt ons and such, so your cause is probably different then mine.
                I was using the ford injectors, maybe one or two were bad, and when I swapped in my oe injectors it was fine.
