Pistons for 2.7L + 885 head?
  • Chuckcruzin1986
    • Jul 2009
    • 130
    Hello,
    I can snatch a new set of these pistons for a real good price.
    http://www.pelicanparts.com/More_Inf...Header=Y&null=
    I have a 1985 2.7L short block that i want to rebuild and will have it honed to the 84.5mm bore. I will be running with a 885 head.
    Are these pistons going to work right out of the box?
    are they ideal for a turbo?
    What length rods should i use?
    Estimated compression ratio?
    Thanks,
    Chuck
  • digger
    • Nov 2005
    • 6192
    Just find a good used eta bottom end
    • redlightpete
      • Mar 2012
      • 265
      If you use your ETA 130 mm rods, you will need to cut 2 mm off the block to get back to stock deck height with the "I" pistons. This should leave you with about 9.5 to 1 compression based on the longer stroke.
      • digger
        • Nov 2005
        • 6192
        I'd only do that for a NA engine
        • Chuckcruzin1986
          • Jul 2009
          • 130
          ways to go
          I want new pistons and a nice straight wall. Why? I had an employee "build" my existing bottom using used super eta pistons, new rings and the original bore which looked good. I have poor uneven compression (105 -130) and a little blow by :(
          Actually, the bottom end that i have is pretty good but don't want to go back to a lot of work and end up with a marginal engine.
          So, would the pistons i am looking at be a good way to go?
          Chuck
          • digger
            • Nov 2005
            • 6192
            How much are the Pistons going to cost ?
            • redlightpete
              • Mar 2012
              • 265
              I think Digger is suggesting that 9.5 to 1 compression is too high for a typical e30 turbo, and if you're not going to use the "i" pistons at the right clearance to the head, you might as well use 'e' pistons... in a stock "e" bottom end. Hence the recommendation. Your super eta is 8.5 to 1, so maybe just a re-hone and new rings would be a good option.
              • digger
                • Nov 2005
                • 6192
                not really anything to do with compression, but if you are paying decent $$$ for new cast pistons and full machine work to end up still a budget build it doesn't make that much sense IMO as you start to get into territory where custom pistons while more $$$ they start to bring much better benefits for not an obscene amount more...
                if a NA engine i say go for it if the pistons are cheap enough
