ETA No Hot Start: I've done everything
  • Maggiolone
    • Oct 2015
    • 56
    I have replaced everything on my ETA except the starter. This includes plugs, coil, wires, injectors, pumps, fpr, cps, ecu, and temp sensor. If the car sits for a few hours after being driven, it cannot fire. Cranks and cranks. Even with starting fluid.
    Is this vapor lock?
  • dnguyen1963
    • Nov 2011
    • 2651
    Do a smoke test when the engine is hot, with the exhaust plugged. Let's eliminate vacuum leaks before examine anything else.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5599
      check;
      spark
      compression
      fuel
      • faber
        • Sep 2017
        • 38
        Jumper your main relay and fuel pump relay to rule out bad contactors. I recently had an issue where the car would start fine and run fine but would not start after it had been running which turned out to be a combination of some funky grounds, bad relays, and a nickel that was rattling around in the steering column and intermittently causing a short. Another thing to look at when it is in a no-start condition is whether or not the coil is firing. Put a 12v bulb across the coil leads (+ and - leads not the coil wire itself) and verify that the light flashes when cranking. if it doesn't then your issue is electrical. If this is the case then start with the main culprits: Main relay, Fuses, Grounding, Crank position sensor plug, C121, and DME (unlikely it is the DME, but there is a procedure for at least verifying the wiring to the DME with a multimeter)
        • jeffnhiscars
          • Jun 2011
          • 6011
          I had the same problem and it was the reference sensors on the bell housing. I have another eta here that I bought as a no start car and I'm waiting for the new sensors for too.
          Let me add that I just switched those 2 connectors on the "no start" car....and it started !! I cannot offer a better example of what can go wrong :-)
          Alice the Time Capsule
          • ForcedFirebird
            • Feb 2007
            • 8300
            Had an eta come in the shop once doing something similar. Turned out one the pins were bent on the ecu connector.
            john@m20guru.com
            Links:
            • Downeaster1
              • Mar 2008
              • 85
              I'm not saying this will solve your problem, I have the same car and had the same symptoms. Turned out to be the valve adjustments were too tight. Had a shop do the valve adjustment, and it was perfect.
              1985 325e Sedan, 1986 325e Sedan, 2006 BMW X5, 2012 M3 Sedan, 2013 135is, 2017 M3 Sedan ZCP Competition
              • jeffnhiscars
                • Jun 2011
                • 6011
                My problem turned out to be plugged injectors due to the car having sat.
                • Maggiolone
                  • Oct 2015
                  • 56
                  So, thanks for all the advice.
                  Turns out the reman injectors I bought were defective!
