The pins on the m20 are heafty and can be smaller diameter, BMW did it on the s54. Just broke two of them for turbo rebuilds, pretty excited to flow the heads personally, but that's for another thread.
Turbo M20 2.8L Stroker w/ 135mm rods
Also best to look at what rings are available, some sizes have more choices. Total seal are great89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Yeah they make more money on gapless, ask them for conventional they have a nice 1mm 1mm 2.5mm with 2nd being Napier. You can just look in their catalog find a size with several options decipher the difference and ask them which is best while telling them the purposeLast edited by digger; 11-01-2017, 09:00 PM.89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
LoL. Digger and ForcedFirebird probably have 10,000 hours engine building experience between them. I would listen to their advice.
My spreadsheet above is a decent approximation of all the stroker data I could find around here. If either of you guys want to tweak the numbers, send me an update. I'll host it and repost."And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
1987 E30 3L Turbo Stroker Das Beast
2002 E39 M5
Originally posted by ForcedFirebird View PostGapless works in boosted applications, but not sure anyone has experimented with gas porting the domed b25 design.89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Originally posted by digger View PostGapless is good for reducing oil contamination so e85 and methanol it's helpful
Originally posted by ForcedFirebird View PostWithout question bore it at least .25mm, but .5 is more common, +1 gives you matching gasket size to bore, which is great to avoid edges and hot spots. I have had blocks measure out for reuse of stock replacement pistons after deglaze, but no quality machinist will hone a used block the extra few thousandths for forged replacements. The bores will not be round. Don't forget to rent a torque plate, your local v8 shop probably won't have an m20 setup. These long siamese engines will move when the head is bolted.
Should I be weary of this? Or trust my machinist?
I have seen quite a few blocks like that, was discussed in the piston thread a few days ago. You can trust him if he carries a warranty. As I mentioned earlier, forgings are going to need more wiggle room. The BMW piston clearances are very tight in stock configuration, much tighter than domestic builders are used to. Did he understand the intermediate shaft bearings?
Originally posted by ForcedFirebird View PostI have seen quite a few blocks like that, was discussed in the piston thread a few days ago. You can trust him if he carries a warranty. As I mentioned earlier, forgings are going to need more wiggle room. The BMW piston clearances are very tight in stock configuration, much tighter than domestic builders are used to. Did he understand the intermediate shaft bearings?
The intermediate shaft isn't quite the quite the same. Most machinists think it's similar to cam bearings from a push rod engine, but those type bearings just press in and done - they will have to be burnished to size - but it's not rocket science for a machinist.
When you purchase pistons, they will come with a pamphlet and specify how much piston to wall clearance is needed depending on coating and such - yes they will expand more the stock castings.
When upgrading rods and going forged pistons, it's a good idea to rotate the balance assembly. If you weigh parts from a BMW engine that has all of it's factory parts, they are extremely close. +/-2gm (4gm total variance).
Originally posted by ForcedFirebird View PostThe intermediate shaft isn't quite the quite the same. Most machinists think it's similar to cam bearings from a push rod engine, but those type bearings just press in and done - they will have to be burnished to size - but it's not rocket science for a machinist.
He is definitely balancing the rotating assembly, that has already been discussed
Who do you guys recommend to order pistons through? VAC Seems to be the only place I've found. I've seen some bad reviews on the Ross pistons through Ireland Engineering. So who do I go with? I've seen digger mention TopEnd as a good supplier for JE.
From their site:
Total-Seal Gapless Rings - NOTE: You use Gapless Top OR Gapless 2nd. You do not do both Gapless.
None
Total Seal Gapless Top Rings (Endurance Road Race, Extreme Turbo and NOS Use) - $38 each + $152 +$228.00
Total Seal Gapless 2nd Rings (Street and mild Race use) - $25 each +$100 +$150.00
Other Piston Options
High Heat Ceramic Coated crowns and Moly coated skirts - $43 each +$258.00
Moly or Tuff coated skirts only - $23 each +$138.00
Heavy Duty Wrist Pins - $15 each +$90.00
FSR Forgings (Limited to certain bore sizes and applications only.) - $20 each +$120.00
Vertical or Lateral Gas Ports (For Drag Race and High Compression engines, also good for NOS use.) - $22 each +$132.00
Contact Reduction Grooves - $8 each +$48.00
Accumulator Grooves - $6 each +$36.00
Milled Side Relief Lightening - $6 each +$36.00
Brushed and Milled Dome Crowns - $4 each +$24.00
That is a lot of options...i dont even know what I do or dont need as piston options...Last edited by SLEEPYDUB; 11-02-2017, 01:06 PM.
