How about High CR Stroker
  • apostate
    • Feb 2012
    • 148
    American Coyotes...
  • digger
    • Nov 2005
    • 6176
    You need an rhd intake
    • apostate
      • Feb 2012
      • 148
      American Coyotes...
      • digger
        • Nov 2005
        • 6176
        you will severely limit topend power and not come close to utilising whatever cylinder head mods you do and the 288 cam won't reach its potential.
        If you're ok with that then fine but it's the reality unfortunately
        • apostate
          • Feb 2012
          • 148
          American Coyotes...
          • digger
            • Nov 2005
            • 6176
            Severely is a subjective term.
            Then why use high cr and 288? Something milder will drive nicer and be better matched
            What ecu ? The standard ecu with 288 and stock alien intake is a grumpy setup
            • apostate
              • Feb 2012
              • 148
              American Coyotes...
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                Your going to want a stand alone
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • apostate
                  • Feb 2012
                  • 148
                  American Coyotes...
                  • digger
                    • Nov 2005
                    • 6176
                    it will run smoother, drive nicer, make more power etc
                    • apostate
                      • Feb 2012
                      • 148
                      American Coyotes...
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        Originally posted by apostate
                        And why?
                        Bacuse MegaDeath is smarter than BMW?
                        Actually it is... so is haltech and any other standalone. Why even ask the question of what else you need if your going to be naive when we give our input. This was just a hey look at what I’m building post.
                        • digger
                          • Nov 2005
                          • 6176
                          no AFM, mine gained 10kw at wheels over custom montronic m30AFM dyno tune
                          has proper tps not throttle switch so better throttle response
                          better control over ICV and strategies used so idles much nicer.
                          you can get in sequential injection helps it run a bit smoother again.
                          you can properly control big injectors
                          you have full control over everything you need. it does take more effort to setup if you dont have a good basemap and there is cost
                          its easy, try motronic if happy then all good....
                          • apostate
                            • Feb 2012
                            • 148
                            American Coyotes...
                            • apostate
                              • Feb 2012
                              • 148
                              American Coyotes...
