How about High CR Stroker
  • ak-
    • 12422
    #31
    Originally posted by rturbo 930
    Maybe it would be better if you took your extraordinary genius elsewhere since all of us plebs are clearly not worthy.
    1991 325iS turbo
    • apostate
      • Feb 2012
      • 148
      #32
      American Coyotes...
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #33
        Originally posted by apostate
        OK, getting out and leaving.
        Hope everyone is happy.
        Didn't get an answer to my question, though.
        Doesn't matter.
        Mamma's forum not for me.
        Goodbye.
        Didn’t get an answer cause you seem to already know. But you may want titanium valve retainers also.
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • digger
          • Nov 2005
          • 6176
          #34
          Obviously, no one knowing the answer on this forum leads to the latest comments above.
          Yes, I am troll. And you know what? Worse, I am Putin's troll. I have to confess this.
          That's why I am bothering you all the time about the M20 or E30, that's the only reason.
          we told you the answers but your eyes appear top be painted on
          the engine will barely if at all make more power than a 2.8L with smaller cam and RHD intake and proper ecu so think about how much you value the sleeper part before spending a ton of $$$ on mismatched parts
          • LJ851
            • 7919
            #35
            CR 11.5-12:1
            Crank 89.6
            Rods 135
            Pistons - custom
            Ported 885 head
            valves - stock size but Different valve shape
            BBTB
            86 mm bore
            camshaft - Shcrick 288
            Shcrick valve springs
            Adhustable cum gear
            TD oil pump
            TD starter
            6 kg. flywheel
            SACHS Performance sport Clutch
            IE fat rocker arms
            What else do I need?
            An open mind.
            Lorin
            The M30 is God's engine.
            • TobyB
              • 5286
              #36
              Adhustable cum gear
              You need 2 of those- one for each cumshaft.
              ...but I'm too late to this party, I guess.
              I was going to suggest trying to put a bigger,
              stock- looking intake on. Or trying to somehow
              dick with the stock intake (cheater inlet underneath, yadda yadda)
              to bypass the long, narrow tubes.
              Dick with, being the operative word here, I guess.
              Only made 3 pages. <disappoint>
              But maybe Aprostate will return.
              Sometimes he does.
              t
              • stonea
                • 2892
                #37
                Is this thread real?
                My Garage
                Feedback
                Instagram: Stone.Hopkins
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3421
                  #38
                  And why?
                  Bacuse MegaDeath is smarter than BMW?
                  I know you're a shit stirrer, but really you're going a bit below even yourself here, how can one claim to know anything about these old cars and not know that Motronic 1.3 is primitive even compared to old megasquirt versions? Anyone with a grain of knowledge on the subject will know it's not about being "smarter" it's about the fact that though BMW engineers were doing the best they could with what they chose, the system they were working with is primitive compared to even low end standalone systems from the mid 2000s, let alone more advanced stuff available today.
                  Hell the flapper style AFM alone is a liability to flow and transient performance, let's not get into the amount of memory in a Motronic box and its proccessing capabilities. Really it's quite impressive they were able to do what they did with so little. The flapper AFM was old tech even in the late 80s when the switch to Motronic 1.3 was made, consider the fact that LH-Jetronic versions from the early '80s onward used by manufacturers such as Volvo were using the superior hot wire AMM.
                  Why do I bother though, this is a guy who considers the stock intake from AFM to manifold a "minor" restriction for an all-out performance engine build with head work and everything.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5270
                    #39
                    Doesn't matter.
                    Goodbye.
                    Maybe if you asked a question and listened for the answer, instead of going full retard...
                    Originally posted by priapism
                    Originally posted by shameson
                    • pandaboo911
                      • 2070
                      #40
                      I don't think he understands the term sleeper.
                      Cars pulling up to the light next to you can't see under your hood.
                      Thanks for leaving the forum, good riddance
                      • LowR3V'in
                        • 4209
                        #41
                        this made me actually laugh out loud twice. thanks for the thread apastat, for real.
                        • 2mAn
                          Señior Mod
                          • 20967
                          #42
                          He's still lurkin
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • zaq123
                            • Jul 2016
                            • 1559
                            #43
                            don't count on it. He said it before in different threads. Guy can't just let it go. AK's post above is spot on, picture says 1000s words
                            • MrBurgundy
                              R3V Degenerate
                              • Mar 2012
                              • 5595
                              #44
                              Aprostate is similar to genital warts. They always come back.
                              • digger
                                • Nov 2005
                                • 6176
                                #45
                                its fun when he is around, imagine if there were 12 apostates around
