How much coolant should radiator take?
  • mc625569
    • Apr 2017
    • 125
    I’m flushing coolant on my 87 325e after a water pump change.
    When i drained coolant I got just under 8 liters which I understand to be low. I have no visible coolant leaks.
    When I refilled it also took just under 8 liters . I had heater on when I refilled.
    Any idea why I’m not taking more coolant ? Could my ancient radiator not be taking the full volume ? I got just under 2 liters in the radiator alone.
    I refrained and filled again filling radiator and block separately and still had same issue.
    I’ve been driving the car and it doesn’t seem to overheat.
    What am I doing wrong, this is my first coolant flush.
  • Echo30V
    • Sep 2017
    • 301
    WHat is the level in the expansion tank when the car is cold?
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Your not getting all the coolant out.You still have coolant in the heater core and will still have some coolant in the block unless you knock out freeze plugs.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • mc625569
        • Apr 2017
        • 125
        Expansion tank level is up to full line when cold.
        How do I drain the coolant from the heater core? I’ve just been draining via radiator petcock and removing drain plug in the engine block and waiting a while.
        • Echo30V
          • Sep 2017
          • 301
          I did not know that changing coolant on the M20 involved popping out the freeze plugs on the block. I never do that, is that necessary? I always thought that draining the radiator and removing the drain plug on the block was sufficient.
          • e30davie
            • Apr 2016
            • 1788
            I wouldn't touch a freeze plug unless it was leaking or i was completely rebuilding the block on the work bench.
            I think you are completeley over thinking this coolant flush, just get out as much as you can by popping off the bottom radiator hose, and fill it back up with new stuff until its full.
            If you manage to replace 90% of it that's pretty good. Its not like that last 10% of "bad" coolant is going to destroy your engine. it will all mix in together and all will be good.
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              Exactly. I should have added i don’t recommend knocking out plugs. How ever that is only way to ever last drop out.
              • Echo30V
                • Sep 2017
                • 301
                Knocking out freeze plugs turns a coolant flush into a big ass job.
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5599
                  What I do for a good coolant flush is; drain the car from the radiator plug, then fill it up with distilled water. I'll keep running water through it until there almost no coolant present in the water as I drain it. Then I add coolant after. That's the best way to get most of the old crap out without knocking out the plugs.
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    The reason coolant changes are recommended every 2 years is to refresh the corrosion inhibitors. I'm sure adding 80-90% of a total fill up will more than serve that purpose.
                    Alice the Time Capsule
