2.7 stroker FPR?
  • krazy
    • Jan 2017
    • 46
    2.7 stroker FPR?
    Hi folks,
    I own a 2.7i 'stoker' setup and I need to replace the FPR. I'm not sure if I should get the 2.5 bar or 3.0 bar FPR?
    The car is an 86 eta base with a full I head swap (including 'i' DME and injectors).
    Also, for my own knowledge, if I were to pick the wrong pressure here, could I damage anything?
    current:
    89 325i
    previous:
    87 325i
    86 325 stroker frankenstein
  • clarkson
    • 231
    The o2 sensor will correct your fueling on idle and part throttle, but open throttle will be soley based on the map programmed into the DME. So, when changing fuel pressure you need to take that into account.
    Having said that, the I head should have the 3.0 bar fuel pressure. Some are using 3.5 bar with tuned engines but with adjustable fuel and timing.
    Pulling my hair out with all these friggin BMW's:
    2000 M5 Winter beater
    1984 318i Coupe 2.5 S14 going in the car below.
    1988 M3 Lachssilber: I'm the second owner, currently recommissioning.
    • krazy
      • Jan 2017
      • 46
      Thanks, clarkson. One other question... is there any risk when switching over to 3.0 bar that any of the stock, eta M20B27 fuel hoses would be incompatible with the higher pressure?
      current:
      89 325i
      previous:
      87 325i
      • jeffnhiscars
        • Jun 2011
        • 6011
        As long as you are using properly size FI rated hoses you will be fine
        Alice the Time Capsule
        • clarkson
          • 231
          Correct. The hose will know no different. Just use 8mm or 5/16 EFI hose, not the cheaper carb low pressure hose.
          Are you running an 885 head on an ETA bottom end?
          • krazy
            • Jan 2017
            • 46
            I’m using standard 8mm hose. CRP hose with matching part number from FCPEuro.
            Yes, it’s an 885 head with an Eta bottom end.
            Thanks for the info, all!
            current:
            89 325i
            previous:
            87 325i
            • ForcedFirebird
              • Feb 2007
              • 8300
              3 bar is proper for stock DME and injector size.
              john@m20guru.com
              Links:
