M20 O2 sensor wiring question
  • cdeason7
    • May 2016
    • 38
    The O2 connector has 4 wires (black, gray and 2 white), I want to confirm that black is power, gray is signal and white is ground. Thanks
  • vpilarrt
    • Jun 2006
    • 2096
    Black is signal, gray is ground, 2 whites (interchangeable) are heater.
    • cdeason7
      • May 2016
      • 38
      Thanks, so what supplies the power ?
      • jeffnhiscars
        • Jun 2011
        • 6011
        Id say the sensor itself, being just a variable resistor, doesnt need power. The ECU reads it and adjusts accordingly
        Alice the Time Capsule
        • cdeason7
          • May 2016
          • 38
          Something has to power the heater part of the O2 sensor
          • e30davie
            • Apr 2016
            • 1788
            Probably best off to grab a wiring diagram from various sources and have a look.
            It's probably powered from one of the main relays as its a fairly large current draw.
            • cdeason7
              • May 2016
              • 38
              I agree, I did find the attached photo but no reference to wire color
              • jeffnhiscars
                • Jun 2011
                • 6011
                Vpillart pointed out there are 2 heater wires so I thought you were asking what powered the sensor side.
                • flumph
                  • Dec 2016
                  • 61
                  There should be an O2 sensor heater relay. In that little relay box next to the AFM. There's 3 relays: one is the main relay, one is the fuel pump relay, and one is the O2 sensor heater relay. Why they needed a separate relay for this, I'm not sure.
                  Also, narrowbands don't actually behave as variable resistors. They're voltage sources, like tiny batteries.
                  Poke around the wiring diagram for your car to be sure though.
                  • cdeason7
                    • May 2016
                    • 38
                    Actually, I am just reusing the connector, I am installing a Wb02 sensor for the microsquirt pnp ecu.
