M20 DME power
  • zaq123
    • Jul 2016
    • 1556
    M20 DME power
    is there any fuse for DME? Thank you
  • ForcedFirebird
    • Feb 2007
    • 8300
    Yes and no. About 12" from your positive battery terminal there's a fusible link on the small wire. That wire should be dedicated to the 10mm hex nut above large battery cable on the fire wall, and go to your main (usually white) relay in your three relay bank.
    john@m20guru.com
    Links:
    • zaq123
      • Jul 2016
      • 1556
      I was wondering if there is a fuse on relay outputs to DME. Looks like it's not there, thanks for answering my question.
