Smoke when opening cap on Valve Head Cover
  • PafuPafu
    • Feb 2018
    • 6
    New to e30 and engines for the matter.
    Opened the cap on the Valve head cover today to refill because of low oil (have to track down the leak still..) and a small amount of smoke was inside. Smells a bit burnt, but also smells like a typical motor. This was after about 15-20miles.
    Could you help me understand why there is smoke inside there?
    Also if you have tips of where to look for the oil leak, I would much appreciate it. I am planning on replacing the valve head cover gasket / adjust the valves soon as there is some oil leaking from the gasket/the bolts on the cover.
    Any tips or information helps! Thank you!
  • zaq123
    • Jul 2016
    • 1542
    just typical blow by....tired engine, nothing out of the ordinary.
    typical places for leaks: pretty much every seal there is in the engine (front and back) and rocker shaft plugs in the head. If everything is still original - bitch tube will most certainly be leaking. Sometimes HG leaks a little.
    • cheffy30
      • Sep 2016
      • 1159
      because its f*cking hot in there...?
      '90 325i sedan daily driven
      '85 325e coupe also a daily
      • PafuPafu
        • Feb 2018
        • 6
        Thank you, makes sense. Appreciate the leads, gives me something to search for / know what I'm looking at better. Thank you!
        When you put it that way... BADASS MAN!
        • e30davie
          • Apr 2016
          • 1788
          Can often be condensation (water) evaporating too. Nothing bad about a bit of condensation.
