Don’t overtighten your water pump pulley bolts
  • jgilber0
    • Nov 2016
    • 457
    Total boneheaded mistake – I misread the shop manual and tried to tighten my water pump pulley bolts to 80 foot pounds!
    In the Bentley manual, nearly all the force specifications for bolts are in foot pounds, but for some reason the water pump pulley bolts are in inch pounds.
    Same thing here:
    I read it three times, and ignored my gut which kept saying “that’s awfully tight for such a skinny little bolt!” Sure enough, one of the little bastards broke off.
    Thank goodness I was able to unscrew the remaining hunk of bolt from the water pump. If that hadn’t happened, I might’ve had to tear down my entire front again.
    Don’t make this mistake!
    Jon (OO=[][]=OO)
    1992 325ic white, stock with a 5-speed swap
    Palm Beach County
  • digger
    • Nov 2005
    • 6199
    I tighten stuff like that by feel lol
    • kronus
      • Apr 2008
      • 13032
      That bolt size is definitely in the category of a very light grunt
      cars beep boop
      • e30davie
        • Apr 2016
        • 1788
        yah, i don't put the torque wrench near anything other than a head bolt and a caliper bolt these days. Learnt my lesson good and proper a few times.
        However breaking stuff is how you learn mechanical sympathy. Its very difficult to describe "tight enough" to someone. You really have to take some heads off bolts to really get an idea:)
        • jgilber0
          • Nov 2016
          • 457
          Originally posted by e30davie
          ...breaking stuff is how you learn mechanical sympathy. Its very difficult to describe "tight enough" to someone. You really have to take some heads off bolts to really get an idea:)
          I’m just glad that was a simple error to fix. Lesson learned!
          Jon (OO=[][]=OO)
          Palm Beach County
