Deep pocket pistons in a stock M20 build
  • jgilber0
    • Nov 2016
    • 457
    After changing my timing belt, I started thinking it would be nice to make my M20 into a non-interference engine. I just use my E30 around town, it’s a cabrio, so no racing and I’m not even allowed to autocross it without adding a rollbar. While I love the MM (Metric Mechanic) 2900, I have a small budget.
    Is it possible to use MM deep pocket pistons in an otherwise stock M20 build?
    What issues might arise from the reduced compression?
    Would driveability suffer?
    Jon (OO=[][]=OO)
    1992 325ic white, stock with a 5-speed swap
    Palm Beach County
  • E30-325iS
    • Sep 2011
    • 191
    There's no point, just keep your maintenance up and you won't have a problem.
    • digger
      • Nov 2005
      • 6206
      the pockets would get too close to the ring groove and may even not be enough crown thickness. MM use a bigger diameter piston and lower the top ring
      • jgilber0
        • Nov 2016
        • 457
        Thanks!
        So much for that idea...
        Annoying amount of work to change that belt. I suppose I’ll get it done faster when I have to do it again in four years.
        Jon (OO=[][]=OO)
        Palm Beach County
        • e30davie
          • Apr 2016
          • 1788
          My timing belt snapped in my car the day after I bought It. Based on the condition of the belt I reckon it had never been changed. It was seriously deteriorated. You rubbed the belt with your fingers and bits of rubber would rub off. What I'm getting at is the belt has to be sooooo neglected to fail. If you change it when you are supposed to you have nothing to worry about.
          • digger
            • Nov 2005
            • 6206
            its like 4 hours to do a TB in a home garage. it will take you more than 4hrs to pull the head and cut those pockets, clean it out and put it back together.
            you would lose about 7cc and almost a full point of CR
