I don't drive my cabrio much these days but about a year ago, after visiting friends, it was hesitant to start. Tried a couple of times then it fired and got me home. More recently, running errands short enough to get it hot, same hard start problem although after a try or 2 it would start.
Last time out it actually died on the way home. Sat there for a minute then started it and drove home.
Running diagnostics in the driveway it would cold start fine the. At OT it would die, even at idle. Give it a rest and it starts.
I've installed a new CTS, NGKs and new FPR, injectors are recent refurbs swapped the coil, main relay & ohmed the CPS. AFM is a fresh Bavrest rebuild, cap and rotor are clean.
Bentley calls a hot hard start to be fuel related so I'm down to fuel pumps failing when hot but haven't rigged up my fuel pressure gauge yet. Just thought I'd put this out there since swapping pumps is not my favorite sport.
