what rating thermostat?
  • bmWes
    • Apr 2016
    • 22
    I have a 91' 325i. I have gone on multiple websites and they all display 71, 75, and 80 degrees C rating thermostats but I cant seem to find which one exactly goes to my car? Can anyone help?
  • e30strokr
    • 211
    from bimmerworld
    "BMW used the same design of thermostat for many models from the 1980s-1990s but with different temperature ratings. This is the 80C degree thermostat (in the middle of the temp scale). 80C was standard on E30 325e/325i, E28 528e/535i, E34 525i M20, E34 535i, E24 635CSi, and E32 735i. Thermostats are interchangeable among the models listed below but note that using a non-standard thermostat will alter your engine's performance. On other models this may be a Performance thermostat used with engine fan delete kits."
    I don't think you will ever see a "higher temperature" T-stat than the standard.. only cooler
    • bmWes
      • Apr 2016
      • 22
      Originally posted by e30strokr
      from bimmerworld
      Thanks for the info
      • e30davie
        • Apr 2016
        • 1788
        I understand the thermostat was specd for your climate so its dependant on ambient temp.
        Have a look on Real oem with your vin number.
        for what its worth there wasa 75 degree one in my M20, and i put in an 82deg one as its what was in stock at the shop. Water temp gauge now says 82deg in stead of 75deg. So no real difference...
        Hotter engines are more efficient. some of the "performance" thermostats get up to 90deg+. Im not sure if i would ever put a hotter thermostat in in the name of "performance"
        • ForcedFirebird
          • Feb 2007
          • 8300
          Thermostat should match the thermal resistor in the radiator. If you put a lower temp t-stat in your hoses, the electric fan won't turn on. The e36 318ti has an 80c thermal switch in it. Threads right into your radiator.
          In the end, the m20 makes the most power at ~92c
          john@m20guru.com
          Links:
          • AndrewBird
            The Mad Scientist
            • 11898
            The temperature rating is when the thermostat starts to open, so the engine will run a bit hotter than that. A hotter thermostat will make warm up time shorter as it opens later. Usually you would use a hotter thermostat in colder climates to allow the engine to warm up more before the cooling system starts to work.
            • htseng
              • Sep 2009
              • 158
              Looks like realoem has my radiator thermal switch at 91/99. Would you recommend the 88-90 deg thermostat and not the 80? Realoem has too many options on thermostat part numbers
