Hi all, this is my first time working on a car so not much experience here.
I recently have gotten a big coolant leak from a hose in the bottom of the water pump. I don't think the engine is getting any coolant as it is heating up to half on the gauge within 5 minutes (I only drove it around the block to make sure the coolant leak was from here).
The red circle shows the hose which the coolant gushes out of. (I think)
I tried tightening the hose clamp, but it still gushed out from that area.
This should mean a new pump right? (just need confirmation before I buy some new parts, I will replace the timing belt also if I need to replace the pump).
I can include more pictures if needed.
Thanks in advance! :)
