Severe (?) Valve cover gasket leak
  • redfoxiii
    • Feb 2016
    • 23
    I know, I know, it's an M20, the valve cover gasket seeps.
    I've had a steadily worsening leak at the front lower corner of the valve cover over the past year or so, no matter how new or which gasket brand I use.
    It's bad enough that the front header heat shield is soaked in oil, and the #1 plug gets a little fouled from the seepage down the threads.
    My question is this: is a head-coating, heat-shield-soaking size leak "normal" amounts of leakage? If not, what would be the fix?
    I've actually begun to wonder if the oil spray tube over the cams might have a loose or backed out nut on that side, which might explain the localized heavy seepage.
    Any advice?
    I wash BMWs all day at a dealership. Do you have any idea how much i8's suck to do anything but look at?
  • digger
    • Nov 2005
    • 6196
    Are you sure it's the valve cover ?
    Check that the valve cover isn't getting hung up on the rocker shaft lock plate. Don't over tighten the nuts and I use permatex non hardening tacky sealant to help
    • jeffnhiscars
      • Jun 2011
      • 6011
      I wouldn't say any substantial leak is "normal". You could have a warped valve cover (lay it on a plate of glass to check) or one of your rocker shaft plugs is either rock hard or not in position.
      Alice the Time Capsule
      • dnguyen1963
        • Nov 2011
        • 2651
        My money is on the shaft plugs too.
        • redfoxiii
          • Feb 2016
          • 23
          Shaft plugs were replaced about 3 months ago with the gasket for a Inspection II service. I always put new plugs in when I do a gasket.
          I’m going to check the cover for warpage next time I have it off, and I also plan to use a coat of RTV equivalent on the new gasket, rather than just where the plug/head/gasket meet as I have been.
