Vacuum in oil pan?
  • Justbergy
    • Nov 2016
    • 41
    Vacuum in oil pan?
    Is there vacuum in the oil pan of an e30. Like I have a small crack in my oil pan and was wondering if that is a problem. Like it's high enough we're oil doesn't ever come out. Just curious. Thanks!
  • cscracker
    • Jan 2017
    • 131
    Yes, it's under vacuum. Any leaks in the oil pan or the dipstick are vacuum leaks.
    • Justbergy
      • Nov 2016
      • 41
      I thought the crank case was vented...?? like to the atmosphere
      • digger
        • Nov 2005
        • 6216
        its vented to the intake between the throttle butterfly and AFM so there is a teeny tiny bit of vacuum. its not on the vacuum side of the butterfly.
        if its a hole then crap can get in from the outside even if oil doesnt come out
        • cscracker
          • Jan 2017
          • 131
          Yeah, the crankcase vent is between the AFM and the throttle body, not to atmosphere. The whole crankcase is under vacuum. If you pull the dipstick while the engine's running (and you don't have a huge vacuum leak) it'll noticeably affect the idle.
          • 325e '87
            • May 2017
            • 503
            Yeah, my engine will come really close to stalling if the dipstick or oil fill cap aren’t making a good seal.
            My son has the 1987 325e, 2 door, 5speed
            I daily the 1989 325i, 4 door, 5speed
            • digger
              • Nov 2005
              • 6216
              Pulling the dipstick is NOT a vacuum leak it's unmetered air. It's not a vacuum leak because it's not on the vacuum side of the throttle butterfly
              • cscracker
                • Jan 2017
                • 131
                Unmetered air is a vacuum leak. All air that gets in but is not measured by the AFM (or MAF/MAP sensor on newer cars) constitutes a vacuum leak (or air leak, technically vacuum can't leak, but it's common parlance). There is no difference whether it's before or after the throttle body, it will cause lean running conditions either way.
                • zaq123
                  • Jul 2016
                  • 1574
                  any benefit to route crankcase vent (CCV) to the intake plenum via catch can-foam filter into the intake plenum of ITBs? I remember deleting CCV on my old e46 and venting it to the atmosphere. It ran like crap so I had to put new cold weather CCV system in.
                  • digger
                    • Nov 2005
                    • 6216
                    I personally don't think there is a benefit except environmental reasons. There just isn't enough vacuum to improve performance
