Best Oil to run
  • AlexSutherland
    • Apr 2017
    • 41
    Best Oil to run
    I’ve been using 5W-30 on my E30. I recently read so many mixed answers for what oil to use. The ones I’ve seen: 5W-30, 10W-30, 5W-40 10W-40, 20W-50 on M20 motors. I thinking about 10W-40 to lower the lifter noise but just want to make sure I’m not going to damage the engine or clog oil lines.
  • 15Michaeljoseph
    • Aug 2013
    • 1693
    Hey man, the 'what oil to run' debate has been covered tons of times, and threads like this usually get flamed by the seasoned members of R3v. Try googling 'e30 what oil to use' or something of that sort and you'll find plenty of information... Most of it inconclusive.
    The weight of oil can depend on where you live/ your climate, and the type/brand of oil depends on what additives you're looking for. Mainstream modern oils don't really have the 'traditional' additives that were spec'd by BMW in the 80's... So your best bet is to choose a good synthetic in the proper weight for your climate, and run it with a OE quality Mann filter for 3-5k, and then change it.
    Personally, for the past 5 years I've owned the car I've been using synthetic Mobil 1 European blend 0w-40 year round (I live in MA, so winter and summer are within the temperature spec). I recently found out that this oil lost it's BMW LL-01 approval, so I may switch brands soon to LiquiMoly or Castrol, keeping that 0w-40 weight.
    Do some research :)
    Sent from my moto g(6) using Tapatalk
    (OO=[][]=OO) For Life
    • cheffy30
      • Sep 2016
      • 1159
      our cars were designed before synthetic was invented.
      go fossil. i like rotella, castroil.
      2c
      '90 325i sedan daily driven
      '85 325e coupe also a daily
      • SkiFree
        • Jun 2011
        • 2766
        I've gotten tired of answering this question every other week, so I just wrote an article on it.
        Here you go.... https://adamsautosport.com/bmw-m10-m...ine-oil-guide/
        ADAMS Autosport
        • ForcedFirebird
          • Feb 2007
          • 8300
          Nice!
          Don;t forget Mobil 1 15w50 is a good box-store oil. We have proven it on the race track, but have actually changed over to LiquiMoly 10w60 about 3 years ago. We saw a 10psi increase in idle pressure with 300° oil temps after hard summer track sessions when we changed. Street cars still get the M1 at the shop, unless they request the race oil.
          john@m20guru.com
          Links:
          • Flying Potato
            • Jul 2018
            • 7
            Thank you sir!
            • Das Delfin
              • Sep 2014
              • 2293
              I use Mobil 1 15w-50 available in a 5 quart jug at walmart for 22 bucks. I change at 7k mi intervals and use the oil year round here in CT.
              Whatever you do, make sure you get an oil that specifies a high zddp content, or buy an additive at autozone and use it with every oil change
              • Bearmw
                • 1323
                I've been using Mobile 1 15w50 in my M30 and it's nice to see confirmation that it is a good street oil choice.
                • 15Michaeljoseph
                  • Aug 2013
                  • 1693
                  Liquimoly Ceretec additive looks pretty good as well, read up on it. I think I'm going to try it out at my next oil change.
                  • digger
                    • Nov 2005
                    • 6211
                    There is no need for additives just oil use an oil with the right stuff in it.
                    • PDXPeter
                      • Apr 2018
                      • 225
                      I just picked up 3 one gallon jugs of Chevron Delo 15w-40 at Costco for $37. Has the same level of zinc as the M1 equivalent.
                      • LowR3V'in
                        • 4209
                        The new vr1 jug looks like a fabric softener bottle.
                        • LowR3V'in
                          • 4209
                          • dnguyen1963
                            • Nov 2011
                            • 2651
                            Stay away from this oil...I think. I used to use Shell Rotella 15W40 then switched over to Chevron because of the price. My car has a small oil drip from the pan now. I think Chevron has more detergent and it cleans the deposit from the oil pan and created my small seepage. It might just be coincidence...
                            • PDXPeter
                              • Apr 2018
                              • 225
                              Cant say I noticed any new leaks with about 100 miles on it since the change. Will watch for it. Already trying to run down a coolant leak.
