885 piston to head clearance
  • Lugnuts
    • Oct 2014
    • 136
    Looking for advice on how much P2H clearance I should be aiming for. 885 head, Mahle Stroker pistons (IE), M52 crank + steel rods (fresh small end bushings), NA engine, DD, so not going to see 6500+ very often.
    Found a few different numbers:
    https://www.hotrod.com/articles/ideal-quench-height/
    Quench should be as tight as possible without the piston actually contacting the head. This, in turn, is largely dependent on the type of connecting rods and the engine’s peak rpm. A good rule of thumb is that you can run as little as 0.038 to 0.043 inch with steel connecting rods. Steel-rod street engines that don’t see the far side of 6,000 rpm may even be able to shave this to as close as 0.032 inch. Aluminum rods expand and get longer with heat, so the quench clearance with them should be increased to 0.050–0.065 inch.
    Don't spend too much time thinking about quench, get it under .050" & above .035" at the squish band & call it good.
    I could fill chapters on these subjects, but its basically not something the average engine builder assembling off the shelf parts needs to be overly concerned with other than to understand the potential power may change due to the parts selected and the careful assembly and measurement during...
    If you are building an engine with steel rods, tight bearings, tight pistons, modest RPM and automatic transmission, a .035" quench is the minimum practical to run without engine damage.
  • zaq123
    • Jul 2016
    • 1570
    about 1mm
    • digger
      • Nov 2005
      • 6206
      I'd aim for 1mm +/-0.1mm
      • SkiFree
        • Jun 2011
        • 2766
        When I developed those pistons I made sure that they little pamphlet that came with the pistons had that info in there. Was it not there?
        Here's another link, unfortunately photobucket nuked the pictures. The information is still the same though.
        ADAMS Autosport
        • digger
          • Nov 2005
          • 6206
          I think he means piston to head clearance not piston to valve clearance
          • Lugnuts
            • Oct 2014
            • 136
            Correct. Thanks for the answers Digger & zaq123 - much appreciated.
            @skifree, thanks for the link - any/all relevant info is helpful. The box does include an A4 sheet about piston-to-bore clearance, piston material composition and basic info on bore size, crank/rod compatibility etc (same stuff found on the IE website). Nothing on minimum/ideal P2H (quench) clearance.
            Edit: there is also the Mahle Motorsport pamphlet which provides guidance on ring-end gaps and ring offset/orientation.
            • zaq123
              • Jul 2016
              • 1570
              Like Andrew said, Mahle should had a booklet in the kit.
              Mahle recommended Piston to Head clearance From the booklet: steel rods - 0.040" or 1.016mm; alum. rods -0.060"
              • zaq123
                • Jul 2016
                • 1570
                it's on the page 2 of Mahle booklet. Not A4 IE print out
Name:	M20 MahleMotorsports Pamphlet 2.jpg
                • Lugnuts
                  • Oct 2014
                  • 136
                  Interesting. Either I've somehow managed to lose it, or it wasn't included. The Mahle pamphlet I have is small (like A5 size), and only talks about the rings.
                  • SkiFree
                    • Jun 2011
                    • 2766
                    Hey.... there it is. Thank you Zaq. Sorry for the mixup, I knew it was in the same pamphlet. There is one in every set.
                    ADAMS Autosport
                    • zaq123
                      • Jul 2016
                      • 1570
                      weird. There should be 2 pamplets, one for rings and one for pistons.
                      Here is page 1 for pistons. Hope it helps. I like Checklist for Success part, truth is told there. Some folks did good work to rebuild M20s, failed to check things and screw up their hard work...as documented on this forum a few times
Name:	M20 MahleMotorsports Pamphlet 1.jpg
                      • zaq123
                        • Jul 2016
                        • 1570
                        you are the one who did the hard part, including these scans ...so Thank you
                        • Lugnuts
                          • Oct 2014
                          • 136
                          Yeah I definitely don't have that. It's entirely possible I've misplaced it, since I bought the pistons 2 years ago. Anyway, doesn't matter! Thanks @zaq123, that's super helpful. Copies saved for (near) future reference.
