Timing belt change cost to do
  • DOC-K
    • Dec 2018
    • 61
    What have you paid to have a timing belt (and pump thermostat hoses etc) done....I realise this is really a DIY job, but if you have paid,,,what was the TOTAL cost?
    BMWCCA 12660
  • e30austin
    • 15382
    Expect to pay in the $500 range, parts and labor. Belt kit and water pump only.
    • ForcedFirebird
      • Feb 2007
      • 8300
      Our current price is $850 for a complete front-motor service.
      This includes parts and labor for the following:
      Timing belt w/tensioner and spring
      Water pump
      Cam seal
      Front Crank seals
      Accy belts
      Oil/filter
      Coolant
      Spark plugs
      Valve adjustment
      Valve cover gasket
      It doesn't make sense to have the belt off and NOT do the things that are behind it, unless you personally know they were done recently.
      john@m20guru.com
      Links:
