engine problems
  • gummaybear
    • Mar 2019
    • 3
    engine problems
    ok so i dont really how to do this i have ask a bunch of people and no one has an answer so i guess i will try this but when i drive my 1989 325i i will loss all engine power for .3 of a second and it will also drop the tachometer and be fine for a little it will happen the most when i am driving around 55 at 2000 rpm and when i frist start to drive. i have no clue why help me please??
  • dnguyen1963
    • Nov 2011
    • 2651
    Check your CPS.
    • gummaybear
      • Mar 2019
      • 3
      Originally posted by dnguyen1963
      Check your CPS.
      i have already looked and replaced it i have tried everything
      • e30davie
        • Apr 2016
        • 1788
        Sounds like a loose connection to me. time to check all of the connections.
        • tomstin
          • Mar 2015
          • 570
          How about the electrical connector under the intake? That’s known to corrode and cause crazy symptoms?
          2004 525i Manual - 1985 325E Coupe Manual
          • sampayne
            • Apr 2014
            • 396
            Check the connector to the coil. I had the same exact systems and it ended up being a corroded connector. Chopped it off, crimped on a new one and never had a problem since.
            Originally posted by 2mAn
            The BMW V6 is the best
            • gummaybear
              • Mar 2019
              • 3
              ok thanks i will try them and see what happens
              • cheffy30
                • Sep 2016
                • 1159
                clean the c191
                '90 325i sedan daily driven
                '85 325e coupe also a daily
                • TobyB
                  • 5298
                  ECU relay.
                  Key switch itseslf.
                  Fusible link in the trunk.
                  t
