Ummmm a little help here!?! Timing belt question!
  • rjsimeon
    • Jan 2019
    • 97
    So, I’m an idiot. I’m buttoning everything up with my timing belt/water pump/crank shaft seal job. Get done with the crankshaft seal and start torquing. Idiotically, I start torquing the E12 bolt and the pulley moves from TDC about two teethe. First thought is to move the crank forward just a bit to compensate. Here are the pics.
    Am I a dumbass for doing that or will everything be ok if I install the timing belt and see if everything is lined up when I rotate the crank when the belt is installed??
    Or, could I just rotate both clockwise till they’re back at TDC? Will I bend the valves at all or damage anything?
  • Joegreen02
    • Dec 2018
    • 80
    Go back to the marks.
    • rjsimeon
      • Jan 2019
      • 97
      Does it matter if I crank it back or do a full rotation forward?
      • Joegreen02
        • Dec 2018
        • 80
        Just go back with everything to the marks, and start your belt installation. Do worry about turning it backwards a little. If you make a full turn with the crank you're going to hit the valves.
        • rjsimeon
          • Jan 2019
          • 97
          Not sure if I’m going to be able to move the shaft back without that E12 bolt not torqued
          • Joegreen02
            • Dec 2018
            • 80
            Stick a couple bolts in the marked drum and turn it back with a bar or screw driver.
            • jeffnhiscars
              • Jun 2011
              • 6011
              There's a key on the shaft so they turn together. In the future never torque anything without a belt and for the crank seal get the pulley holder. Your dealing with 300lbs of torque
              Alice the Time Capsule
              • rjsimeon
                • Jan 2019
                • 97
                Worked. Thanks a lot.
                • rjsimeon
                  • Jan 2019
                  • 97
                  Yeah. Stupid mistake on my end. Thanks for the advice.
                  • Joegreen02
                    • Dec 2018
                    • 80
                    You bet. Good luck bud.
                    • rjsimeon
                      • Jan 2019
                      • 97
                      Buttoning everything up and this little guy is left in my radiator hardware bag. Any idea where this is from?
                      I may have just thrown it in there without even thinking and it may not even belong in the radiator bag...definitely belongs inside the bay somewhere.
                      • Joegreen02
                        • Dec 2018
                        • 80
                        Doesn't look familiar to me bud.
                        • rjsimeon
                          • Jan 2019
                          • 97
                          Interesting. Alright thanks.
                          • zaq123
                            • Jul 2016
                            • 1560
                            it is definitely not oem
                            • rjsimeon
                              • Jan 2019
                              • 97
                              Yeah, it's driving me crazy thinking about where it came from. We'll see what happens when I flush/bleed coolant tonight and start her up.
