M20 disappearing coolant mystery
  • lindskrot
    • Aug 2016
    • 13
    Hi everyone.
    I have a m20 with M54B30 internals, Schrick 288 cam, 3mm MLS gasket and quite high compression.
    I have had the car for 2 years and it has always used a tiny amount of coolant.
    But last 2 weeks it suddenly uses huge amounts of coolant but i have no clue where it goes!
    Oil is perfect. No sign of water
    No signs of coolant on the ground
    no visible white smoke out the tailpipe
    running fine
    not overheating
    It goes from full reservoir to warning for low coolant in less than 10 miles.
    Any ideas where it may go?
    Heater core? But by now it must have leaked out at least 10 liters that way and i should notice that in the cabin i presume?
    head gasket? But should it not be bellowing white smoke with the rate of water disappearing? Or watery oil?
    Worst case, cracked head? but that should also give smoke?
    I really have no clue where it goes. All ideas helpful!
  • lindskrot
    • Aug 2016
    • 13
    Also, if i change head gasket, should i go for MLS again, or a cutting ring head gasket?
    • e30austin
      • 15382
      Pressure test your cooling system, both when cold and warm. That might give you a bit of an indication as to what's going on.
      • SethB
        • Feb 2015
        • 88
        Bad/loose reservoir cap maybe? Pushing coolant out the overflow at the top of radiator, around a bad cap seal, and out the overflow hose? I had a bad cap seal a while back that was letting that happen, couldn't figure out where it was going until I let the car warm up in the driveway and coolant started running out of the fender well.
        ClassicBimmerBits.com
        Garage:______________________________________
        -1989 Alpinweiss II 325i - Other Daily Driver
        -1989 Zinnoberrot 325i - Daily Driver
        -1974 2002 - Weekender
        -1989 325ix - Totalled :(
        -1981 320i - Sold
        -1986 Porsche 944 Turbo - Sold
        • digger
          • Nov 2005
          • 6199
          give it some revs in the drievway for a while and see if you can see a leak
          • turbski
            • Jul 2018
            • 329
            Is your floor soaked by the trans tunnel or down by the seats?
            • lindskrot
              • Aug 2016
              • 13
              No water under seats or inside the car.
              After some more testruns, im more and more convinced the head gasket is the issue. It started putting out a bit of smoke during last drive.
              I changed my faulty expansion tank cap, and this probably increased the pressure in the cooling system, wich also increased the smoke.
              If the head is warped, how do i check this? can i use a metal ruler to check for straightness?
              • digger
                • Nov 2005
                • 6199
                Straight edge or flat surface with feeler gauge
                • zaq123
                  • Jul 2016
                  • 1560
                  pick up the leak down tester.....or cheat and just pressurize each cylinder with the compressor and the compression tester fitting into each spark plug. If any bubbling in the coolant...HG is no good at that cylinder
