Blue Smoke when hot or high RPM
  • ADEN
    • 620
    My engine was rebuilt 8 months ago,
    New valve guides
    New valve seals
    New rings
    Water pump
    Oil pump
    Head machined
    He said pistons groves where a little worn and where i live i couldn't find new pistons so i had to put my old back.
    Right after the rebuild engine smoke blue when hot and idling only, oil consumption 1/4 every 700 kilos.
    Maybe stupid mechanic was wronge at some point, but why smoke when hot not cold?
    Only thing he didn't change is the head bolts.
    Can a loose and hot head let oil escape to the combustion chamber causing blue smoke and fuel consumption????
    1989 320i m20b20
  • Jaxx_
    • Dec 2009
    • 1880
    Does the engine miss at all? does it run well? was valve stem to guide clearance checked? how do the spark plugs look?
    • ADEN
      • 620
      Yes, engine miss when niddle in the middle, valve stem to guide clearance idk my mechanic did it, spark plug foulded.
      • ButtJuice
        • Dec 2009
        • 2609
        Needle? Middle of what, temp gauge?
        1991 318is - Sold
        1986 325 - Sold
        Instagram - Lamoursum
        • jeffnhiscars
          • Jun 2011
          • 6010
          If he didn't hone the cylinders the rings may not bed and seal and head bolts are a one time use so no telling if the head gasket is sealing.
          Alice the Time Capsule
          • ADEN
            • 620
            Thanks but please confirm, loose head can let oil enter the crankcase and burn?
