Weird Main Relay Issue
  • ryan.of.peachey
    • Apr 2019
    • 77
    '88 325i vert. Engine only starts/gets spark when I jump the main relay, it won't start with the actual relay installed. I've tried two brand new relays (both are OEM) and neither work. Is it really possible I bought two bad relays? What else could be causing this problem? Thanks.
    Sent from my SM-G960U using Tapatalk
    1988 Alpinweiss 325i Convertible
  • digger
    • Nov 2005
    • 6215
    Test the relay pins using 9v battery or similar and see if it switches correctly
    • ryan.of.peachey
      • Apr 2019
      • 77
      I'll try that. Just wondering what else it could be. I'm stumped.
      • jbontke
        • Mar 2019
        • 449
        If you know putting power from #30 to #87 lets the car run, I would focus on #85. I think that is the ground signal form the ecu?? Wiring diagram says its a green wire from the MCU called the "Main Relay Control"
