88 M20 upgrades while 5spd swapping
  • thejimlab
    • Oct 2004
    • 588
    So, much to the chagrin of my wife I bought another project. It's an 88 325 auto. I will be pulling the engine/trans to do a 5 speed swap. While its out I'm going to change timing belt and water pump. Here's the important question. What else should I do to it? I have everything (I think) to swap it to motronic 1.3. Pull the head and install "i" cam? Headers? lightweight flywheel?
  • nrubenstein
    • 3148
    There’s absolutely no reason to pull the engine for a 5spd swap.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Rev Run D
      • Feb 2013
      • 392
      This. but if you're gonna:
      oil pan gasket
      clutch/flywheel
      motor/trans mounts
      steering rack
      cam seal
      coolant lines
      • redlightpete
        • Mar 2012
        • 264
        Your 88 should be a “super eta”, so it would be a good candidate for an “I” cam and ecu upgrade. As said above, you don’t need to do that at the same time as the trans swap, but if you do take the motor out...
        • Andre3127
          • Dec 2017
          • 291
          Pull the engine. It's easier and safer.
          Budget E30 Parts - Used and Reconditioned parts for your BMW
          • ryan.of.peachey
            • Apr 2019
            • 77
            Also a good time to check and replace any rubber, ie. fuel lines, coolant, etc.
            Sent from my SM-G960U using Tapatalk
            1988 Alpinweiss 325i Convertible
