Anyone have the PN for these handy ?
FI Harness to Valve Cover Clips
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Tags: None -
On the drivers side there are 2 clips bolted to the VC that hold the fuel injector wires. They are opposite where the plug wire loom bolts. This should help
[url=https://flic.kr/p/2gzutiM]
Last edited by jeffnhiscars; 07-15-2019, 12:32 PM.Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
Bracket is NLA. I couldn't even get a part number, but saw it in a diagram (or it was superseded). For thing like that I hit them on the wire wheel (or media blast) and hit them with cold galvanizing compound or silver paint.
Is that wire off the main chassis harness, or engine harness? From memory, don't think it's part of the engine harness.Comment
I'm not sure what you media blast. I could probably grab the FI loom off my parts car but I believe it's part of the fuel rail and I'm not about to swap all that out. Not a big deal either way.
It's the tail end of the engine harness so both of those wires run across the upper timing cover. The big plug goes to the later style oil pressure sender which is all of $5 so I'm ordering one (current sender has a spade connector). I just can't see anything that bullet connector goes to.
Edit....my cabrio has the same bullet connector with a blue/white on the engine side attaching to a black/white so I found it on the ETA. It's by the wiper washer pump and runs along the drier and towards the pass side head light. No idea where it goes from there but it's connected lolLast edited by jeffnhiscars; 07-16-2019, 07:44 AM.Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Ding ding ding...it's for the AC. Pins 40 and 41 on the ecu both have blue/white wires. One goes to the "AC control switch" the other to the low pressure switch. Its one of the other as I read itSeat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
