how much power from 2.9 stroker?
  • winstontj
    • Mar 2007
    • 500
    Just wondering. I have not done a compression or leakdown test on my motor but it came with a dyno sheet stating 178rwhp. Wondering what the 2.9L stroker motors put out with ~10:1cr pistons & moderate cam.
    Do they achieve 250 at the wheels?
  • backtrail69
    • Jul 2005
    • 4471
    The highest I have seen is Jordan's old 2.8 stroker at like 210ish RWHP. He had extensive head work and high compression.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • winstontj
      • Mar 2007
      • 500
      Should I be happy with my 178rwhp then? The dyno sheet is about 4 years old and with the way the motor is running I'm debating paying for a dyno session to get it back to that state (after I do a comp & leakdown test).
      For all I know it could be a stroker.... Haven't even pulled the valve cover yet. If I had a stock exhaust (which I do I think) and stock motor could it be possible to get to that 178rwhp number on a bav auto chip, MAF conversion, uprated injectors & other little bits or would it take more like headwork, cam & exhaust?
      Thanks for the reply.
      • digger
        • Nov 2005
        • 6081
        it was 192whp
        • Addissimo
          • Mar 2004
          • 1820
          Originally posted by digger
          it was 192whp
          word.
          ~220bhp.
          too bad he burned oil.
          Doing something M50 related? -> http://www.addissimo.com
          On Myspace? ->http://groups.myspace.com/r3vlimited
          BF2142 SN = BillyGoose
            • 34839
            you must mean 86mm bore/84mm stroke?
            I don't know how much power it would make, but it would have a ton of torque. it's probably a better idea to tune the M20 for a wide torque band than trying to go after peak HP #s. if I did it again, I would go with the 84mm crank instead of the 81..
            • Sean
              • 5793
              Chris...I hear ya.
              I've been enjoying mine...but when I do another one, and someday, I will (I'll turbo this one someday) - I'm going to do pretty much Metric Mechanic's biggest stroker - but of course, source out the parts myself. :D
              Strokers are fun, but they are not powerhouses...frankly, the M20 is a great motor, but it won't be breaking any power records staying NA. Just fact of life.
              Still a fun motor though! GOD I LOVE TORQUE! :D
              - Sean Hayes
              • winstontj
                • Mar 2007
                • 500
                it was 192whp
                178 isnt that far off from that. How can I tell what (if anything) has beem done to the car? I have to adjust the valves soon so there is a start but what about bottom end?
                Will I be able to tell the crank differences any other way? If I had to guess I would have said it was stock but if you guys say that 192 - 210 takes work then it makes me wonder.
                I have very little records and hve no idea who the PO was
                • SA E30
                  • 1248
                  I dont think I would build a stroker with a longer stroke than 84mm... just not sure how well it will rev...
                  but then I also wasn't sure that my 84mm stroke would rev that well, and it does... so maybe 86mm throw wont be that bad :)
                  • StereoInstaller1
                    GAS
                    • 22679
                    Another way to build a really torque-y stroker is to start with an M30 block... Just kidding, man.
                    178 is a hell of a nice number from a mild stroker, even though yours sounds more than "mild".
                    Several others have made the observation that BMW never really raced the M20, but ran the shit out of the M30 (S38,S88, etc) and the M10 (S14) blocks and learned a bunch with the M50 series.
                    I do wish I had your motor though.
                    Luke
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • winstontj
                      • Mar 2007
                      • 500
                      Funny thing is I have no idea what is in this motor. I haven't even pulled the valve cover and before I started digging around here & e30tech I would have sworn up and down that it was a stock displacement motor because that's what the PO said.
                      Also I'm sure that I'm probably only getting ~150 to the wheels right now because the car runs like SH*T. I need to do a bunch of work on it. I'd love to just buy a bunch of parts (like vacuum hoses, spark plug arrangements, etc.) and pay for a dyno session and someone who knows how to tune these things to teach me what's up.
                      I also have stock exhaust (header but with stock cat & exhaust) so that's probably holding back more that the motor could put out. Even more funny is I only use the car to go to whole foods once a week and on weekends... other than that it just sits.
                      ~200 at the wheels (NA) must be effing fast though. Even with my lowly 178rwhp the torque is awesome. I'm trying to get the documents scanned and put up so I can post torque numbers too. I think I'll just look for a dyno and get another tuning session so I'm not running around saying something without PROOF!
                      • backtrail69
                        • Jul 2005
                        • 4471
                        You've been driving 2002s too much...those are slow, thats why it feels fast. :P Get in my over 250 whp (don't have a real number yet) turbo m20, you will feel what a m20 feels like when it isn't breathing through a straw...
                        :: PNW Crew ::
                        • winstontj
                          • Mar 2007
                          • 500
                          That's my e30 and a stock 2002 combined.
                          Seriously can a stock displacement m20 even with cam & hi comp make 178 at the wheels? I have a hard time believing that this is a stroker and the PO didn't know about it. He was building an M6 race car and has an e36 m3 track car. He also had about 6 s38 motors laying around his shop. I'd think he would know enough..... This is bugging the hell out of me!!
                            • 34839
                            at the wheels? it would be tough.. but possible I think.
                            • PeaveyBassist
                              • Sep 2004
                              • 3511
                              For reference, new stock engine can dyno around 152whp.
                              Will
                              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                              Welcome e30 (brilliantrot '90 325is) 12/23/06
                              DaveCN = Old Man
                              My signature picture was taken by ME! Not by anyone else!
                              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
