The m20 seems pretty smooth at idle. Is there a better upgrade than urethane MMounts? PO had installed a heim joint from the motor to the chasis to prevent movement. I'd like to remove that but install something a little more stiff than stock.
Is it true that urethane mmounts and rubber trans is the way to go?
The motor does not jump or miss at all. Is there anything else I'm missing that will make me regret removing this motor movement arm and not just going to stock rubber?
